460 gasser in an IDI
Ok, before you guy's tell me Im crazy I have a few question's.
1. I assume I can drop a 460 gasser in a truck that has an IDI in place, what mount's and crossmember do I need?
2. What tranny ( automatic ) should I use? Keep in mind I need OD.
3. Driveshaft?
4. Do I need to change the wiring harness? I would be using MSD ignition but will everything else be ok,like abs?
5. It would be a carb. engine so Im sure I need to flush the tank's and such. Any info on this swap?
Don't panic, Im not doing this to the truck in my sig,although I am still fighting brake problems with that one!! I found another truck and the drivetrain is wasted,I have a killer 460 built for a truck and this look's like a prime candidate for it so Im thinking about it.
93 F350 super cab w/7.3 IDI non turbo, E40D,4.10's,no soup bowl,custom fab'ed ram air, pretty much a stock truck, lotsa diamond plate, custom console,500 watt pioneer, General Lee cb w/ 800 watt red devil and a monkey made antenna,when I key up the mic, you listen to me,lol  123,000 miles
