Old 03-30-2005, 02:34 PM   #1 (permalink)
4x4 use
Guys, please excuse my horrible lack of knowledge when it comes to 4x4. This truck is my first.
I was doing some thinking about 4x4. I have read that some newer trucks have a 2-Lo setting on their transfer case. That is a good thing to have when pulling a boat up a steep and slippery ramp, or backing a trailer up a steep hill (i.e. my driveway!). Going up the ramp, you are basically going straight, so 4-lo would work correct?
Everything I am reading says 4 wheel drive engaged is ok if in a straight line on paved surface. You have problems when you start turning.
Now, when backing my boat up my driveway, I have to hit it on an angle, and turn, so 4-lo is out of the question. My truck has no 2-lo setting.
So, here comes my brilliant thought. Set it to 4-lo, and don't lock in the hubs. This will prevent the front diff from binding I think.
I know next to nothing about 4wd systems, so I figured I'd better ask before I go and do something stupid. Will I hurt my 4wd system by running in 4-lo with the hubs free? Kinda a red-neck 2-lo system I guess.
Ryan
1988 F250 Supercab, 4x4, 7.3 IDI, C6 Auto, 147K miles
Banks Sidewinder non-wastegated Turbo, Stage 1 Injectors, and Pyro, Boost and Water guages.
My Gallery
analog is offline
Old 03-30-2005, 02:41 PM   #2 (permalink)
Re: 4x4 use
I'd say your right on. That's what I'd do anyway. By not locking the front hubs, your correct that it shouldn't bind or cause any problems.
Neal in MN
2005 F350 4x4 Crew Cab, short bed.
1980 Mercedes 300D
Sold - 1990 F350 [img]/ubbthreads/images/graemlins/frown.gif[/img]
V2Neal is offline
Old 03-30-2005, 02:46 PM   #3 (permalink)
My Photos: (23)
Re: 4x4 use
Agreed. I'd say 95% of my use of 4 lo is without the hubs locked. Great for creeping trailers around.
- Mel
1983 F-250HD 4X4 The Moose Truck - Moose Pump, DPS Injectors, Hypermax Turbo, GV 7spd., 3.54 Gears, Moose Air, RDT, Dual Stacks, 35"tires. My Album 55MPH at 1400 RPM. 19MPG Avg.
1993 F-350 CC DRW The Lady Moose - Hypermax Turbo, GV 9spd w/Double OD. 4.10's. Dual Exhaust, custom trim, turned up 6.9 fuel system, Lucky Flywheel.
1987 Bronco The Moosestang 1987 Bronco Diesel 6.9L C6 4X4 with 3.54 gears, 2" body lift.
HeadGasket/Turbo Article
A BOOB man! Visit EZBoard.com and search for IDI.
agnem is offline
Old 03-30-2005, 03:26 PM   #4 (permalink)
Re: 4x4 use
i use 4 lo with the hubs unlocked all the time it works great for trailers and places when you need to go slow
2001 dodge 2500 24 valve cummins diesel 6 speed strait piped and that is it SOLD my 1994 F250 4x4 IDI turbo 5 speed reg cab xlt 3 in strait piped200,xxx miles headache rack with tractor backup lights chrome brush guard 105 gal fueltank gooseneck hitch rebuilt inj pump turned up with pyro looking at boost gauge and injectors
1990 chevy ld2500 4 speed v6
2000 polaris xpedition 325 4x4 5 speed
kcyard is offline
Old 03-30-2005, 03:28 PM   #5 (permalink)
Re: 4x4 use
That's the way to get 2-lo. No transfer case that I've seen has a selection for 2-lo.
Casey_1 is offline
Old 03-30-2005, 03:58 PM   #6 (permalink)
Re: 4x4 use
Thanks for confirming my thoughts guys.
Now that I have this truck, I plan to stop using my 5spd Dakota for putting my boat in the garage. I just hate the smell of the poor clutch when I get done with that task. With the lo setting on the xfer case, the F250 should do the job much easier.
Ryan
My Gallery
analog is offline
Old 03-30-2005, 07:13 PM   #7 (permalink)
cdnsarguy's Avatar
My Photos: (74)
Re: 4x4 use
Since you have manual hubs has anyone tried leaving 1 front one unlocked, the only time windup comes into play is with both fronts locked in I believe..........am I out in left field again.... [img]/ubbthreads/images/graemlins/shrug.gif[/img]
Proud Canadian BOOB man too!!
cdnsarguy is online now
Old 03-30-2005, 10:07 PM   #8 (permalink)
Re: 4x4 use
I think some old jeeps were the only transfercases with 2 levers 1 for 2wd or 4wd and 1 for hi/lo range. I have a 2wd gas rig with the lame zf rev. and man, let's just say I always use 4 low when backing the trailer on my diesel. you won't hurt anything.
2005 f250 xl reg cab 4x4 6spd
HughJazz is offline
Old 03-30-2005, 10:49 PM   #9 (permalink)
Dave Haven's Avatar
My Photos: (16)
Re: 4x4 use
I think some old jeeps were the only transfercases with 2 levers 1 for 2wd or 4wd and 1 for hi/lo range....
[/ QUOTE ]And I've heard they had an interlock to prevent shifting into low range w/o engaging the front end to supposedly prevent the possibility of sending excessive torque to the rear drivetrain.
I often use "2 low" on my '89 for loading my camper and backing trailers. It normally won't cause any problems.
If you're not careful, though.... [img]/ubbthreads/images/graemlins/tongue.gif[/img] I tried "2-low" on my old Bronco once while trying to climb a steep hill... I "Tootsie-Rolled" the rear drive shaft. [img]/ubbthreads/images/graemlins/tongue.gif[/img]
"Big Red"-'89 F-250 4X4 reg cab; 7.3; Cat ELC (no problems, ain't skeered ; 4.10 axles; 5-speed ZF "Bolt-Action"; ATS turbo installed @ 158K; Holley "Red" pump; new injectors and 2nd Reman IP@ 234.5K; "Coffee Can" (4") downpipe-back exhaust....
6220#
"Trick Truck"- 1970 F-350 w/custom utility bed and cabover camper; Cadillac leather seat; CAT 3208 w/turbo from CAT 613 scraper; 5" straight pipe; 6-speed Allison "slush box"; 3-speed "Brownie"; 2-speed Eaton rear axle from F-600; Custom rear deck w/ air compressor, Lincoln arc welder, Oxy-Acetylene rig, and boom crane....
17,940# 26' Class C motorhome
"White Pony"- 2007 Mustang; 4 liter V6; "5-shot bolt action" (an automatic in a Mustang is just WRONG!)
Dave Haven is offline
Old 03-31-2005, 12:04 AM   #10 (permalink)
Re: 4x4 use
I don't think so, If they did it would be simple to bypass. Because 2 of my friends operate their jeeps with 2 wheel low range. (sometimes it helps on the trails) The torque numbers weren't really high in the 1940 neither. The np205 can also be modified to operate this way for guys with lockers in the front this is a huge benefit, it saves unlocking the hubs sometimes when you have to turn sharp on muddy hills.
HughJazz is offline
Old 03-31-2005, 03:55 AM   #11 (permalink)
d9d
Re: 4x4 use
hmmm....wouldn't the open-diff in the front cause the torque to be sent to the "free" side? I.e. what would be the 'spinning' wheel in a slip situation.
Analog; you quoted one source as saying to use 2-lo for "steep and slippery boat ramps". That's not quite right. You'd use it for -steep- ramps, but for -slippery- you'd want 4wd. Lo-range can actually exacerbate spin-out problems because there's just so much torque going to the wheels. It's hard to control it enough to prevent break-loose.
On a slippery ramp, I use 4-lo, but I don't worry about it even in turns, because it's.....slippery! [img]/ubbthreads/images/graemlins/biggrin.gif[/img]
A -little- bit of driveline 'windup' isn't a problem, as long as you are being careful with the go-pedal. The tires will generally slip/scuff to equalize on their own. However, if you're in a tight turn on bone-dry pavement, and whack the go-pedal hard in 1st-gear 4-lo,, then yeah, you'll probably break something expensive...
My Rig: 1991 F350, 4x4, 5-spd, 7.3na, 4.10 solids, std. cab, flaking factory blue... [img]/ubbthreads/images/graemlins/grin.gif[/img]
My other diesel is a...
Hydra 35-ton Excavator, 6V71T; Isuzu C201 genset;
'71 VanPelt Pumper, Cummins 855 Turbo
There used to be a link here, to some useful IDI-diesel tech info; but it was chopped out by others, in a vain attempt to repress the very essence of the internet: linking!
sigh...
d9d is offline
Old 03-31-2005, 11:31 AM   #12 (permalink)
Re: 4x4 use
Heh, the source quoted was my poor brain [img]/ubbthreads/images/graemlins/eek.gif[/img]. You make a very good point, and of course, slippery is just what 4-lo is good for. Thanks for clarifying.
Ryan
My Gallery
analog is offline
Old 04-04-2005, 10:26 PM   #13 (permalink)
Re: 4x4 use
Having 4x4 locked (Lo or High) and engaged will bind most systems while on solid dry surfaces. If your driveway is loose or wet, etc. you should be OK in 4x4 Lo/locked. I would do 2LO as you describe, if your driveway is paved, etc.
Enjoy your 4x4!!! [img]/ubbthreads/images/graemlins/cool.gif[/img]
"You gotta get your mind right" Cool Hand Luke
(Paul Newman)
1988 4x4 F350, 7.3IDI, ZF 5spd(5th syncro gone), SRW, 4.10 LS (worn clutches) Std. Cab Stock, Rough Paint Rough bed. 190,000 miles Multiple fuel/air leak/supply issues. Did the soup bowl.
New ZD-9's. New Batts. Fuel returns and inj cups repaced sometime ago. Donations accepted.
cetanicult is offline
» Sponsor Links
»Garage Storage and Cabinets
