7.3 cylinder head bolts? - Diesel Forum - TheDieselStop.com
Old 10-19-2005, 09:39 PM   #1 (permalink)
Is there another source besides Ford for these? It's like $160 for the set from them. ARP doesn't make them, nor does FelPro that I know of. Any other sources for these? Thanks
Bug
1986 F-250 Lariat Supercab 4x4 6.9L diesel (the best $350 I ever spent [img]/ubbthreads/images/graemlins/smile.gif[/img] )
1991 F-SuperDuty rollback 7.3L diesel / ZF 5spd (now with a torched wiring harness)
Bugzturbo is offline
Old 10-19-2005, 09:43 PM   #2 (permalink)
My Photos: (24)
Re: 7.3 cylinder head bolts?
sure and the best ones appear to be the ones from Ken at dps.
Was - 12/92 f350 jasper 7.3L
Is 12/92 f350 - 4.10 open, DRW CC with 5.9l CTD BANKS IC.
Getrag 360
- exekiel coolant filter system (Fleet-guard filter and dca)
- Agnem starting system :-)
more pics
BOOB Man
exekiel69 is offline
Old 10-19-2005, 10:31 PM   #3 (permalink)
cdnsarguy's Avatar
My Photos: (109)
You could try IH they built the engine.......
Proud Canadian BOOB man too!!
cdnsarguy is offline
Old 10-20-2005, 07:34 PM   #4 (permalink)
No way in hell I'm paying $600+ for some studs unless they come with a harem of nekid women who will install them for me. I'm doing a head gasket job on my tow truck, not building a 2000hp tractor pull rig. I'm looking to spend less than what Ford wants as $160 for a set of bolts is high in my book. Thanks though.
Bug
Old 10-20-2005, 07:39 PM   #5 (permalink)
Tried that already (coincidentally, there is an IH/Mack/Kenworth dealer right next to my local Ford dealer). They're actually more than Ford at around $220 a set.
Bug
Old 10-20-2005, 08:44 PM   #6 (permalink)
rawpower's Avatar
looks like you're paying $160 a set
1993 Ford F350 7.3L Turbo Diesel ZF S5-42, Divorced TS NP205, OEM locker/welded 2.5 ton Rockwells, 46" Michelin XML's, and some stuff too.
http://www.supermotors.org/users/RAW_POWER
rawpower is offline
Old 10-20-2005, 09:36 PM   #7 (permalink)
My Photos: (24)
Bug
LOL Man I understand that too, I wanted He's stage 1 injectors but something got on the way and could not get them [img]/ubbthreads/images/graemlins/shrug.gif[/img] . You can get them from the stealership for $160 and have the same results everybody else does. Now some times you can get smocking deals on fleabay.
Getrag 360
more pics
BOOB Man
Old 10-20-2005, 09:48 PM   #8 (permalink)
typefour's Avatar
I just got a quote from Quality Diesel here in portland and they were aboue 40 per head, I am going to find out who makes them and post. I forgot how much the parts for these overhauls are, thank goodness they last looooong time. To used to chevys and VW"S I guess.
91 F350 crew cab 4x4 7.3 ats and intercooled with cut down 2000 ps cooler, bigger turbo comp,head studs, torque cam, coated rockers , balanced. very good power.
pyro,boost and all stock guages ignored with mechanical real ones
Fugitive sandrail. type 4 2840 turbo fi, lots of fun
PM please not visitor message
typefour is offline
Old 10-20-2005, 10:33 PM   #9 (permalink)
Yeah, I already spent $150+ in gaskets, $400 at the machine shop to redo the heads, $200 for 8 new injectors (since 2 were broken anyways), $40 for return hose and nipple kit, $80 for glow plugs, etc, etc, etc. At this point, yeah, what's another $160. But DAAAAAMN this is getting expensive. All because of a blown head gasket. If this wasn't a tow truck, I'd be even more P O'd about it, but it's one of those things that HAS to be done.
Bug
Old 10-21-2005, 12:40 AM   #10 (permalink)
hey,I'll do your engine if you do mine.......little over 700 for IP and injectors,900 for brand new heads,600 give or take for pistons,440 for reman turbo rods,couple hundred for rod prep,Not to mention gaskets,bearings,crank and cam recondition,lifters,rockers,pushrods,880 for block work........and this is just for a slightly upgraded and strengthened 7.3L.I will NOT go into the "Other" build.....OUCH!
IDI Till I Die!!!
NCC-1701UAV U.S.S. Enterprise -1991 F350 CC dually.Execution coming soon.
1994 F350 Crew Cab Dually,7.3 IDI turbo-Blowed up. White Lightning
1971 M35A2 deuce and a half. Martyr Machine
1971 M35A2 deuce and a half.Messiah
1957 M52 gasser 5 ton tractor
1968 M543A2 5 ton wrecker sent to china in tiny peices.
Cousteau 2006 Ranger STX-3.0 V6,5spd handshaker,standard cab
Beware of Steelsoldiers.Run by Liers and backstabbers.
m35a2 is offline
Old 10-21-2005, 01:12 PM   #11 (permalink)
What makes you think you need to replace the head bolts? BTW, Kens studs are 270,000 psi and your stock head bolts are 153,000 psi. You can reuse the studs over and over but at some point reusing the bolts has to stop. They do get "tired"..... [img]/ubbthreads/images/graemlins/eek.gif[/img]
icanfixall is offline
Old 10-21-2005, 03:29 PM   #12 (permalink)
[img]/ubbthreads/images/graemlins/eek.gif[/img] [img]/ubbthreads/images/graemlins/eek.gif[/img] [img]/ubbthreads/images/graemlins/wink.gif[/img] BTW, both your pumps are up here. [img]/ubbthreads/images/graemlins/grin.gif[/img]
Ken
'01 F-350 Oxford White, 4x4, Auto, CC, LB, DRW - Lots of stuff
'85 F-250 Reg cab 4x4 6.9 - The new puller.
psychostroker is offline
Old 10-21-2005, 06:49 PM   #13 (permalink)
Because they're TTY bolts. Supposed to be replaced every time. Plus a few of them were actually somewhat loose, indicating to me they may have stretched over the 15 years and 160k miles of use. I'm not worried about getting anything that is reusable though as I will NOT be doing this again.
On the upside, I did find them. Victor Reinz (the gasket company) has them. My buddy who did the heads (owns a machine shop) found them from one of his suppliers for around $110 a set. About $50-60 cheaper than Ford, and probabaly the same bolts too. I'll post the part# for you guys when they show up in case anyone in the future may be looking to do a stock rebuild.
Bug
Old 10-21-2005, 09:53 PM   #14 (permalink)
My Photos: (16)
I don't think they are TTY
Try Napa, they'll be cheaper.
Poke Here!
'93 F250 SCab XLT, 4X2- 7.3/ZF5/4.10 Banks Wastegated Turbo, Enviro-assult tube
'85 F250 Reg Cab XL, 4X2-6.9/C6/3.54 Racor, Holley Red, Auto Jet 3" out, Air Ride Rear
'93 F150 Reg Cab XLT, 4X4-5.0/AOD/3.55 Pacesetter dual out, Timbren Rear
Some pix/ The fleet
Zrob is offline
Old 10-22-2005, 12:45 AM   #15 (permalink)
Sweet,I'll give you a call Saturday.
IDI Till I Die!!!
m35a2 is offline
