HI i have a 7.3 diesel in my 92 f350 and it sucks at pulling everything i notice jsut a car trailer behind me. WHat do i do is there any power mods that i can buy that really work? Can i swap the motor with a turbo 7.3 out of a 94-97? or should i turbo the motor i got? what is the best please resopnd asap Thank you frank
You can turbo the one you have...... but what overall condition is the engine in, what mileage. Check the oil filler/timing cover tag for correct year punched out...... is it a 92 or 92.5.
How new are the IP, injectors, has it been timed......
iof you need a bit of power here and there then get propane or water injection
if you need general power from start to stop get a turbo
if the engine is good then the turbo kit would be best
88 F-250 body,550 rear frame setup, 7.3 idi, 3:73 dana 80 rear, srw, dana 50 front, heavy duty leaf springs, back up camera, 20$ wallyworld fog lamps, class 5 bumper hitch welded to frame and gusseted, brush guard with front mount hitch, 32" steering tires all around, ac power converter,jeep bucket seats, deezee runningboards (cab only),cobra 29 cb w/ 102" whip, 2 trucklight worklights on front stake pocket each side,high lift jack behind seat, toolbox for the junk, visor, running lights, 6600 lbs with all my junk
If you need a price on a turbo kit, or just a part of one, pm me and let me know. But you should do it soon as they're going to be discontinued in December.
<div class="ubbcode-block"><div class="ubbcode-header">Quote:</div><div class="ubbcode-body"> If you need a price on a turbo kit, or just a part of one, pm me and let me know. But you should do it soon as they're going to be discontinued in December. </div></div>
WHAT??? WHY??? That sucks!!!
Heath
__________________ 1986 F250HD 4x4 7.3L IDI '95 PSD front clip, '97 bed, T19, D60/10.25 with 3.55's. Rebuilt from the frame up. Banks Turbo, DPS IP & Stage 1's, Isspro TTM, Banks Exhaust, Boost gauge, Pyrometer, Precharged Coolant Filter, Holley Red Pump. 16.5 x 37 x 12.5 Goodyear Wrangler's, Air Horns. 6in lift, Fresh Paint, On-board Air. Revamped Interior. Rhino Liner.
It's all a matter of how many are made and sold per year. We've had these in production for the better part of 20 years now and there are a lot of them out there, but the demand is no where near where it used to be. If there's enough interest in it they may keep it going but for now it's on the chopping block. So if anybody needs them, or if you just need the turbo kit (no exhaust or gauges) itself, let me know. They are still available and they still have a 5 year warranty.
bankspower, Since you're here, can I ask you a question?
My Sidewinder will make max 7-8 psi at WFO. I've have a DPS modified IP and injectors. My EGT's rarely see more than 650-700 at max boost at WFO. To me, these numbers seem low. Even with the wastegate disabled (for a short test, it's hooked up now) the max I saw was 10 psi at WFO.
What do you think? Any other compressor/turbine wheels for the Sidewinder to increase boost?
Thanks,
Heath
That system was never ment to go above 12psi max at sea level. This was mostly because of the compression ratio and a concern about the head gaskets. Unless you do something custom that's as high as it's going to go.
Did Banks make a turbo for the IDI before the sidewinder? I have a Banks turbo on my truck but it has a different airbox than the sidewinder kits i have seen on other trucks.
1992 F250 4WD, super cab, auto., Banks turbo and exhaust.
More to follow once I figure out the diesel animal. Usually just play with gas.
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: graygriz03</div><div class="ubbcode-body">Did Banks make a turbo for the IDI before the sidewinder? I have a Banks turbo on my truck but it has a different airbox than the sidewinder kits i have seen on other trucks. </div></div>
Back then there were 2 sidewinder kits. A wastegated and a non-wastegate. The non-gated was ment for vans and motorhomes not trucks, but they were slightly less expensive so people put them in trucks as well. We still have the pressure box and air filter for the wategated set up in stock if you need one. They can be used on the other types.
