I need a rebuilt set of heads, for a 1988 7.3. ......anyone have a good set, reasonable? my local machine shop doesn't seem to want to do a valve job on mine, says cost could be as much as $800. Is this the usual?
88 superduty, F450, rollback, 5 speed
95 Dodge, 2500 service truck, Cummins, At, 425k miles
OUCH,for $800 you can nearly buy 2 brand new heads!!!I paid $150 this last time for a total R&R of both my heads.The First time was $100 a year ago and now it was a wopping $75 a head for Pressure check,Facing,weld any cracks,seats cut,rocker surface faced and trued,Bead blasted exterior and a warrentee.Alabama Cylinder head exchange.
IDI Till I Die!!!
NCC-1701UAV U.S.S. Enterprise -1991 F350 CC dually.Lighted heated west coast mirrors,Nathan Airchime K3HA air horns,attitude from hell itself!
1994 F350 Crew Cab Dually,7.3 IDI turbo-Currently in the Roundhouse awaiting 10 year overhaul. White Lightning
1971 M35A2 deuce and a half.6wheel drive,Power Nothing!125 Horses in a 13,000lb truck.Real get up and go power! Martyr Machine
I can only advise, see your local IH dealer for rebuilts. There are tons of rebuilt heads out there and rebuilders which aren't worth the time of day.
There are specific minimums in head thickness, valve face depth and valve stem height that come into play. An American Engine Rebuilder's Association shop will have all the correct info required to do a good job.
Check Ebay for Clearwater Cylinder Heads in Clearwater Florida. They have new and rebuilt heads. The new ones are $375.00 each and the rebuilt are less than that. They have a wab site but I don't have it. Not hard to get in touch with them. Dieselcast Welding is also another place that sells new and rebuilt heads. They are located in Portland Oregon and Minn. Good luck hunting....
