Old 01-11-2006, 01:31 PM   #1 (permalink)
7.3 IDI with an EXHAUST BRAKE
I know they say your not supposed to use and exhaust brake on a 7.3l but I was wondering if anyone is useing one, or has used one on their truck. I'm just curious because I have seen them on other fords but never had the chance to talk with the owners.
Are they worth the cost? Has anyone had any bad experiances with one?
Any thoughts on this?
94 F-350 CREW, FACTORY TURBO IDI, 10PSI BOOST, 3in STRAIGHT PIPE EXHAUST w/ BANKS DOWN PIPE, K/N FILTER, AUTOMETER GAUGES, BUILT E4OD, 4.10 gears, 200,000MI. 6 245-75-R16 TERRA-TRAC M/T's 2-KC DAYLIGHTERS
Ironman03R is offline
Old 01-12-2006, 03:15 AM   #2 (permalink)
Re: 7.3 IDI with an EXHAUST BRAKE
Ironman,
I have had a US Gear Ex. break for a year and a half on my 6.9 w/3" exh. no muffler, [img]/ubbthreads/images/graemlins/biggrin.gif[/img] and it works great. At higher RPM it stops the truck almost like a panic stop. [img]/ubbthreads/images/graemlins/shocked.gif[/img]
Dan
1984 F250 4x4, t19, 3.55, 3"strait pipe, US gear exauhst break, mech. gages, tach, warn winch, 15,000 on rebuild.
rough_rider2 is offline
Old 01-12-2006, 11:40 PM   #3 (permalink)
Hey Dan
I found the us gear website. Did you really pay $1200. for their exhaust brake?? Thats a crazy price. I want an exhaust brake in the worst way but I cant justify spending 1200. bucks for one of those. Any other suggestions for an E brake?? I have a 94 F350 CC dually with the 7.3 IDI Thanks
1993 F350 Dually CrewCab 7.3l IDI XLT. Bone stock but the possiblities are ENDLESS. Added a triple pillar pod for pyro, trans temp and boost. Coolant bypass with upgraded coolant and Im workin on more stuff! I think Im addicted!!
KillerK9 is offline
Old 01-13-2006, 05:09 AM   #4 (permalink)
i have always wanted one for pulling through the mountian passes in alaska. Does anyone know if there is a cost effective way for renforcing the top end to accomodate a EB?
--Ryan
91 f-350, dually, 7.3 diesel. 2wd, 4.10 gears LS. E4OD. New injectors, lift pump, and fuel filter at current 85,000 miles. Autometer pyro and fuel turned up. 3" exhaust with walker "btm" muffler
http://community.webshots.com/user/olivera_149
olivera149 is offline
Old 01-13-2006, 04:31 PM   #5 (permalink)
My Photos: (5)
I had looked at them when I owned The Enterprise but never could justify the cost... Then I got my current truck which it had one on it when I purchased it and whoa boy I should have added one to The E long ago. I will not own another diesel without one period.
Now on mine I upgraded the exhaust springs so that I could plug up the hole in the butterfly so that I could get more braking power from it. I'm sure that we were to measure out the exhaust springs on an IDI then contact a spring manufacturer that they might have something that could be put in it's place that would have more spring tension that could work. What I would do is find out the specs of the stocker springs then contact someone like Crane Cams or K-Motion or the like to see if they have a valve spring that fits the bill. Never know they might have something...
Travis
Will Work For Diesel Fuel.
argve is offline
Old 01-13-2006, 10:55 PM   #6 (permalink)
--Ryan
Ryan
I dont honestly believe that there is a need to do anything to the top end. Ive been doing extensive research to buy one and nobody has even mentioned the top end. There was some concern from the manufacturer of the original JAKE BRAKE, about lifter damage because they are hydrolic not solid but everybody that Ive spoken to, that has them, say they work great. The basic principal is that they restrict exhaust flow out of the motor causing it to slow down. I just havent found one priced right for me. I refuse to pay $1200. for one made by US GEAR. If you find any cheaper or from another maker let me know, Im having some trouble. Good Luck
KillerK9 is offline
Old 01-14-2006, 03:52 AM   #7 (permalink)
BD (diesel/performance) sell inline exhaust brakes.I think they are around $1000/$1100 Canadian dollars...The have a good web-site and brochures on all there products..
Cory
1992 F250 XLT 4x4 reg cab 7.3 na auto.120,000 miles
285/16 BFG AT,16x8 allum rims
Banks Y pipe to 3" stainless/flowmaster with 4" stainless tail pipe.
Stainless over axel traction bars w/stainless axel brkts.
Stainless upper and lower F/axel spring brkts.
Stainless sway bar links and brkts.
Powerstroke bumper insert
Firestone Air bags (rear)
stacked plate trans cooler with gauge
Temro resirculating block/water heater
Rancho RS9000 shocks
Allum box liner
1936 Diamond T 212bd
1968 Mustang FSTBK 427 4 spd
1967 Mustang 289 5spd
Originaly member #8410
diamondtguy is offline
Old 01-14-2006, 01:23 PM   #8 (permalink)
I've got a BD exhaust brake on my truck. It has been *very* useful when going down the mountain passes on the Alacan when I'm pulling fully loaded trailers. Spendy, but definitely worth it if you're doing lots of mountainous terrain with trailers.
Peter
1988 F-350 7.3L Diesel, 130k, CC, SRW, 4x4, ZF5, 4.10 gears, Gearvendors Overdrive, Detroit True-Tracs in front and rear diffs, Banks Sidewinder Turbo, LUK flywheel, BD Power Exhaust Brake, IP turned up, 9' dump flatbed.
Peter C is offline
Old 01-15-2006, 10:55 PM   #9 (permalink)
I have had my US GEAR Exhaust brake since 1999. The brake is great in the mountains. It will save you from frying the truck service brakes when you come down a long steep grade. I know because I did it one time. If it saves you from boiling your brake fluid and loosing your brake once it will pay for it’s self.
1989 F250 4X2 Super Cab 7.3 idi Sidewinder Banks Turbo and exhaust system 5 speed 4.10 gears, US Gear Diesel Exhaust Brake, Fuel Transfer Main Tank
kiteflyer is offline
Old 01-16-2006, 01:33 AM   #10 (permalink)
Rich2
I paid $850 for a 3" HD w/ the bypass valve. this was 2.5 years ago & worth every penny. Try driving a truck with one, you will be imprested. [img]/ubbthreads/images/graemlins/biggrin.gif[/img]
Dan
Old 01-16-2006, 12:47 PM   #11 (permalink)
I found one in the "for sale" section of this site. The gentleman wants $250. for a jacobs brake plus shipping. I would still need to get an air compressor set up to run the actuator and a micro switch to have it work automatically when I throw the switch. meaning that if the switch is activated, whenever I took my foot off the pedal, it would automatically turn the brake on. He also recommends a torque lock up and I would need to buy flanges for my exhaust becaue the inlet/outlet are 4" so I would have that issue as well. so Im loking at the floowing expenses.
$305. shipped to the door
$150. for an air compressor set up with a tank(which I could use for my future air ride system)
$40. for the microswitch
$25. for the flanges
$25. misc. for wiring, cab switch fuse link ect.
Is this worth the trouble or shold I just get the whole kit from US gear or something like that. The more I type the more I wonder if its worth my aggravation??? some advice PLEASE!!
KillerK9 is offline
Old 01-16-2006, 02:36 PM   #12 (permalink)
pontoonrob's Avatar
Call U.S. Gear--- 1-800 8473271. They match their brake to specific valve spring loads.I think thats the only safe way to run one.They are friendly people.I bought mine from a TDS member pretty reasonable.it works pretty good [img]/ubbthreads/images/graemlins/biggrin.gif[/img]
l988 F250,4x2 XLT extended cab,-- 7.3,naturally aspirated IDI, 185hp,5speed gear rower, dueling pyrometers,-- persons+engine+gear=6990lbs!12-18mpg.
pontoonrob is offline
Old 01-16-2006, 02:52 PM   #13 (permalink)
my brother uses one that just turns the warm-up valve into the exhaust brake. slows him down great and he has no issues fo 70k miles and about 5 years. he bought a kit from somewhere that uses a coouple relays and some wiring. it is all just plug and play sort of stuff. [img]/ubbthreads/images/graemlins/shrug.gif[/img]
2008 FORD F350 6.4l 6spd. bone stock
2004 polaris predator 600 big bore boondocker nitrous
2006 suzuki hayabusa 10.7@132
bryonl is offline
Old 01-16-2006, 04:26 PM   #14 (permalink)
My Photos: (5)
On the PSD with the backpressure valve you can do this but an IDI does not have such an animal.
Travis
argve is offline
» Sponsor Links
»Garage Storage and Cabinets
