7.3 IDI F250 solenoid wiring diagram - Diesel Forum - TheDieselStop.com
post #1 of 2 (permalink) Old 02-12-2012, 07:10 PM Thread Starter
Good evening:
I am in Haiti with a 1992 F250 7.3L IDI Diesel . There are no dealers or garages who understand a 7.3 diesel F250.
I had to change out the battery wiring harness and have 2 dilemmas.
1. where may I obtain a wiring diagram for the solenoid??
2. How do you tighten the starter/solonoid cable at the starter??
I have tried every size "tork" bit I have and have had no success.
I am not a mechanic but with the help of folk like you in the USA I have been able to keep me trucks running for 32 yearsm but now I am at a loss. I have searched the forums on thios site as well as other sites but find no help. Thanks for taking the time to read and hope you can help.
wftw4haiti is offline
post #2 of 2 (permalink) Old 02-12-2012, 10:10 PM
drinkypoo's Avatar
My Photos: (25)
Wire from the ignition switch energizes the small terminal on the start relay after passing through an interlock switch, wire is red/light blue. it should be the same color all the way back from the relay through the interlock to the ignition switch on the column assembly. Cable from the D/S battery passes to the P/S battery and from there feeds the starter relay and heads to the starter. Starter relay energizes the starter solenoid.
I don't know if any of our old school buses from the USA have gone to Haiti, they certainly have been sent to a lot of other countries. If so, whoever services those will be probably be able to service your truck. In general most of the older long-nose school buses seem to be international IDI V8 powered while the flat-face ones are pushers with Cummins.
I have a Nippon Denso starter and the hot lead mounting is different from the stock unit. It's sold as a "heavy duty" starter for the same motor in applications from Caterpillar etc. Bolt-on replacement. So I'm afraid I can't help you there.
1997 Audi A8 Quattro 225k Warm/Cold packages
drinkypoo is offline
