Old 07-30-2008, 02:26 AM   #16 (permalink)
Originally Posted by Snotzalot View Post
FWIW air in the lines usually exhibits itself as "Starts the immediately dies".
Yeah - mine has started that, and I have a running leak of fuel, too, to track down....I'm guessing those are related symptoms...
1993 F350 XLT Crew Cab 4x4 factory turbo diesel, 5-spd, 4.10s w/towing package, bench seats (fits family), white paint, sprayed bedliner, "Rackit" lumber rack.
This was exactly the truck I was looking for...
now 282,000 miles & 6 yrs (factory reman engine @ 119K miles)
14.5 mpg @ 65 mph cruise control & AC
Casually looking for a good used overdrive....
Real trucks don't have spark plugs!
-Guy-
Escondido, CA
GuyW is offline
Old 08-03-2008, 10:22 AM   #17 (permalink)
danngreen's Avatar
Definitely. I replaced all my return lines except one (IP return) and it was still stalling, but would always start back up. replaced that last line with 5/16" 30R7 and has been running great for 2 days. FWIW, the returns were 3/16" 30R7
My first project truck: '90 F250 7.3L IDI 2WD, camper shell, primed and ready to pick color(s). Dual exhaust
WORK DONE: replaced starter, new return lines/injector-caps, new glow plugs/wiring harness/controller-relay, wiring fixes, replaced brake cylinders/pads, two-tank SVO conversion
danngreen is offline
Old 08-12-2008, 09:52 AM   #18 (permalink)
Hmmm,
My van's been harder to start the past few days, it's been much cooler overnight here. Anyway, I've been cycling the glowplugs 3-4x then trying to start. When it cranks it's slow at first then speeds up and eventually starts, I get a small cloud of white smoke that quickly goes away. I haven't tested anything yet but it seems as though the starter or batteries may be the culprit. Aside from disconnecting and voltage testing the batteries and measuring GP resistance is there a test for the starter? Van is about to kick over 90k original miles so my guess is most stuff is original including the starter and solenoid but I have no way of knowing for sure.
rsr911 is offline
Old 08-12-2008, 12:15 PM   #19 (permalink)
Snotzalot's Avatar
A volt meter is 10 bucks down at the corner store. Pull the starter out, inspect the Bendix end bushing, take it to a starter repair shop and have them test it. You could also place an amp meter on the positive cable at the starter and read the draw.
Inductive ammeter
These type of inductive amp meters are sold at most auto parts stores.
FWIW there is an interesting article attached to this link that shows how to test the charging circuit using simple tools.
Regards,
Paul - Pocono Mtns. USA '90 E350 7.3L Ex-Ambulance High Top 400K Miles, No Turbo, Stock Stock stock, 10 oz. Bars Stop Leak and No ELC!
7.3L Alternator Belt Idler Photos
Snotzalot is online now
Old 08-14-2008, 10:28 AM   #20 (permalink)
Originally Posted by icanfixall View Post
A gear reduction starter will spin the motor about 500 rpm. Mine usually starts before I can let go of the key... Get a Mistibuchi gear reduction starter. Its the differance between night and day....
Is gear reduction starter standard equipment... or is this one of those things that was "discovered" after our trucks were made?
'88 F250 Lariat extended cab ?10,XXXmi, C6 Auto, 3.55 rear, 16" Aluminum Summit Racing Rims, LT235/85R16 Bridgestone Duelers, Sony Xplod CD Reciever, Mostly OEM replacment parts, for now...Lovingly named "Brownie" simply because its brown and a sweet ride .
dieseldude73idi is offline
Old 08-17-2008, 06:19 PM   #21 (permalink)
I wonder if my starter is my starting issues also. Mine takes some cranking also but I do have a fuel leak but like mentioned air in lines will usually die after it starts. It looks like ip is leaking not really sure from were. I drive this thing maybe once a week so the fuel leak is not a very big issue. I was going to change over to electric fuel pump this week and see if this helps just as a starting point.
02 Ford Excursion 7.3 powerstroke 2wd. Rancho RS9000, B100 summer, B50 winter
94 F350 Crew Cab 7.3 idi turbo, no muffler, B100 summer, B50 winter
rodman68 is offline
Old 08-19-2008, 01:27 PM   #22 (permalink)
Question on the mitsubishi gear reduction starter looking at parts suppliers website they are all mitsubishi straight drive. One site says there is a different one for the idi turbo versus the 7.3 non turbo. Were did you get this mitsubishi starter at, because I cant believe this starter is different because the turbo. I have found the nippon denso on ebay will that work?
rodman68 is offline
Old 08-19-2008, 01:29 PM   #23 (permalink)
Also if the engine is cranking slower that would mean the mechanical fuel pump is running slower and having a harder time getting up to pressure.
rodman68 is offline
Old 08-20-2008, 02:56 AM   #24 (permalink)
Well I killed my starter this morning trying to start the truck. It sat all day and I put a charger on it one battery while I put the starter in after work. Wow was I amazed, the engine barely turned over before firing up with a vengence! It literally started faster than anything I've ever seen, I don't think it even completed a full revolution before firing up.
I (we) really need to look at these engines for what they are, high compression. My drag car had 13.5:1 and would barely start with a race starter and one battery, I got a second battery in there and thus faster spinning and it started much better. Since diesels rely soly on compression to start it only makes sense that higher rpm cranking will start quicker/better. It's been getting cool here at night and I've been plugging in the block heater but I left it off tonight to see how well it starts in the morning.
rsr911 is offline
Old 09-13-2008, 10:31 PM   #25 (permalink)
Alrighty... whats the best route to take, are all the ford diesel starters interchangable (6.9idi-late7.3)? Theres one on Diesel Starters & Alternators 100% New Great Price that looks awesomely beefy. I like beefy.
Old 09-17-2008, 08:28 PM   #26 (permalink)
Wow - I don't know how that site sells those starters so cheap! NAPA rebuilts and independent shop rebuilts around here cost $230 or so...
-Guy-
Escondido, CA
GuyW is offline
» Sponsor Links
»Garage Storage and Cabinets
