Old 10-08-2006, 12:02 AM   #1 (permalink)
7.3 IDI straightpiped AWESOME
Man today I heard the best sound exhaust on any car or truck ever. This kid who has a older 7.3 91 I believe straightpiped his truck or i think he did. I went over to ask him a few questions about it but he was kind off quiet about what he did. But boy this thing is wicked when he gets on it. Very intimidating. Its a true dual exhaust to with 5 inch chrome tips coming out at 45 degree angles in the back. The older 7.3s without turbo sure dont make the power the newer trucks do but boy the sound makes it sounds like a big block gasser. Anybody have this setup on there trucks?
2003 7.3 F-250 Reg cab
49369 is offline
Old 10-08-2006, 05:25 PM   #2 (permalink)
Re: 7.3 IDI straightpiped AWESOME
I have a single exhaust with a glasspack and 4" tip, sounds the same as a straight pipe just not quite as loud.
Jimmy C.
89 F350 7.3 IDI Diesel, 110,000 miles, Black and silver, single cab long. 4x4 XLT Lariat. 5 Speed Manual, very clean truck. Banks sidewinder kit, 4" dual stainless magnaflow exhaust, 4" skyjacker suspension kit with rear add leafs. Chrome Pro Comp wheels, 35" Pro Comp Mud Terrains.
JCDiesel89 is offline
Old 10-10-2006, 08:46 AM   #3 (permalink)
My Photos: (23)
I did that to the Moosestang when I first built it. But unlke an F series where the exhaust exists 10 feet back, on the Bronco, it was about 2 feet back. I drove around thinking I was carrying a huge sign that read "Arrest this man" [img]/ubbthreads/images/graemlins/eek.gif[/img] Not only that, but my fillings were coming loose. I stuck a pair of cherry bombs in the side pipes and never looked back.
- Mel
1983 F-250HD 4X4 The Moose Truck - Moose Pump, DPS Injectors, Hypermax Turbo, GV 7spd., 3.54 Gears, Moose Air, RDT, Dual Stacks, 35"tires. My Album 55MPH at 1400 RPM. 19MPG Avg.
1993 F-350 CC DRW The Lady Moose - Hypermax Turbo, GV 9spd w/Double OD. 4.10's. Dual Exhaust, custom trim, turned up 6.9 fuel system, Lucky Flywheel.
1987 Bronco The Moosestang 1987 Bronco Diesel 6.9L C6 4X4 with 3.54 gears, 2" body lift.
HeadGasket/Turbo Article
A BOOB man! Visit EZBoard.com and search for IDI.
agnem is offline
Old 10-10-2006, 10:51 AM   #4 (permalink)
Have a single 5" straight pipe on my turbo IDI... sounds mean as all hell ..
1991 F350 Crew Cab Dually 7.3 IDI, ATS Turbo kit, ATS highflow exhaust, TransGo shift kit, Airstroker rear air suspension, 4.10's, trans-oil cooler, camper shell (off the turck) [img]/ubbthreads/images/graemlins/smile.gif[/img]
F350TDD is offline
Old 10-10-2006, 03:52 PM   #5 (permalink)
I want duals on my truck. 89 7.3 IDI. I think I will have to have them custom bent.
1989 F-250 7.3 Diesel 75,000 miles
Nitrochris is offline
Old 10-11-2006, 03:58 PM   #6 (permalink)
My Photos: (38)
We have a 4" straight exiting to the side, in front of the tire on the 93 turbo dually. Sounds pretty good, raps like heck.
some stuff
14.8 @ 90
gregrob is offline
Old 10-11-2006, 06:27 PM   #7 (permalink)
My one housemate had a single 3" on his 6.9, and it sounded, very, very nice. Recently he put a 4" dynomax race bullet muffler on it, and it quieted it down just a tad, but still sounds nice.
Mine has a 2 1/2" straight pipe into 3" tips, and I think it sounds decent, just not deep enough.
Another housemate(as well as my ol' man) has 2 1/2" duals with cheery bombs on theirs, and it sounds alot like a big block gasser.
88' F-350 reg cab, SRW, 4x4.
7.3/ZF5, 4.10's and 33's, rear locker,
banks turbo, 3.5" straight pipe, pump maxed, and advanced 2 degrees.
89' F-150, 351, 435, dual T-cases, rear discs, front electric winch, PTO winch rear, OBA, 40's
Jrod13 is offline
Old 10-11-2006, 06:44 PM   #8 (permalink)
Hello all, my 1989 F-250 has the good ol' 3" straight pipe, from the Y-pipe all the way back, with a 5" slash cut tip. Sounds loud, and is more than capable of setting off car alarms (oops?...hehehehe....), and drowning the 3,000 watt sound systems in cheap import cars. Also, it sounds real good when the engine's noise resonates off the walls on the highway. STRAIGHT PIPES ARE AWESOME!!! "LOUD PIPES SAVE LIVES"
1989 Ford F-250 (My first diesel, and still own!), 4x2, straight cab, Ford/Sterling 10.25 Rear w/ 4.10:1(Factory!), ZF 5-speed, K&N Air Filter, 3" Straight Pipe (Y-pipe back) w/ 5" tip 265/75-16 rubber, bought w/ only 78,XXX on the clock.
damien is offline
Old 10-11-2006, 08:13 PM   #9 (permalink)
My Photos: (12)
my 6.9 has the factory ypipe into a dynomax bullet muffler, the to 4 inch stack. yes, stack.
sounds great.
but i now have headers on the way, gona run dual bullets and dual stacks. still probly gona throw a h pipe in.
83 F250 6.9 rebuilt at 280,000. NP435, NP205, 4x4 conversion with hp60 front, 10.25 rear. 35inch Cepek Mud Countrys - RESTING IN PEICES (PARTED OUT)
99 Expedition 5.4 gasser
2000 F550 Lube Truck (Work Truck)
Certified PA Inspection Mechanic
i'd rather be 6.9'n than cummin or strokin'!
CowKiller is offline
Old 10-15-2006, 02:31 AM   #10 (permalink)
biodieselLuke's Avatar
I had a 4" setup from just below the manifolds back on an 86 350 that exited in front of the rear wheel . That thing sounded MEAN ! My roomates hated it when I left for work in the morning at 4 am . It was a 4x4 welding truck and I'd always get called to recovery/repair missions . The bystanders always claimed they could FEEL the exhaust blowing on them from 30+ feet away when redlined pulling somebody out
02 f550 crew cab, harbor body, 312k, BTS, Itp reg. return, turbomaster, ebpv delete, HP x-over, ford ais, aih delete, Diesel innovations up pipe, 4" cat back, ccv delete
86 f250 4x2 4 speed 6.9 115k
85 300sd 265k
09 vw tdi 1k
biodieselLuke is offline
Old 10-15-2006, 06:54 AM   #11 (permalink)
strait pipes are the way to go. its the real sound of the engine no changes, i love it. I have an 86 F250 with a 6.9 and it has strait pipes with the factory pipes up the the bed then 4 inch stacks. it gives me good backpresure for excelleration with a louder sound and the 4" stacks give it a good ecco. when my 86 F250 with the DT466 is done I will have 4 inch straitpipes with 6" dual bullhauler stacks.
1987 F350 4 Door 6.9IDI 5Spd Banks Turbo Dually -1986 F250 Reg Cab 6.9IDI 4spd 4X4 Dually-1988 F250 Reg Cab 7.3IDI C6-1985 F250 Ext Cab 7.6 DT466 10spd
http://community.webshots.com/user/MyDTpickup
INTERNATIONALDIESELPOWER
MyDTpickup is offline
Old 10-15-2006, 06:08 PM   #12 (permalink)
I've got dual straight pipes on mine and it sounds deadly. wouldn't trade that sound for the world!!!
1988 F250 lariat 7.3 idi non-turbo. 4" body lift. bfg tko's 315/75 r 16. 355 gears. dual 3" straight pipes (forgot the mufflers. ooops...). and the all important fresh black paint and way too much diamond plate.
bigdug is offline
Old 10-15-2006, 09:04 PM   #13 (permalink)
Now on these 80's and early 90's fords what they sound like.. ( i am just getting into ford diesels so not familar with them) but i know the dodge diesels sounded like a roaring semi truck coming down the road........... whats these older fords sound like??
Do they sound like them big 400 gas motors? or dound like a diesel semi?
THanks
1987 Ford F-250 6.9 IDI 5SPD 4x4 with warn whinch and Mostly Stock 180,000+ And running strong and healthy ...veary pleased.....
Hillshadowacres is offline
Old 10-15-2006, 10:13 PM   #14 (permalink)
My Photos: (12)
sound like a bigblock, but....different.
Old 10-16-2006, 12:28 AM   #15 (permalink)
I always thought that a straight piped 5.9 Cummins sounded about like DT-361 in a Farmall 1206. The semi is close also. If you know what a 534 Ford V8 gas in an early 60's straight truck with dual straight pipes sounds like, you might get close to the 6.9/7.3 They have enough displacement to mimic the high compression of the 6.9/7.3. The 351M/400/429 and 460's, just dont have the deep bellar 6.9/7.3's do. The 534, OR a 430 Lincoln V8...Helped a buddy restore a 63 Lincoln Continental had a set of custom headers on that baby, and we took it out on a fresh solid lifter rebuild....SOUNDED AWESOME till we got a little to heavy on the go pedal and hopped a pushrod, whoops. No damage and the "stinkin lincoln" lives to fight another day. Those 2 are about as close as you'll get...
Shawn
Custom farming in NWIA.
tractors:
706,806,1206,1256,5288,7140mfd.
vehicles:
-1985 Ford F250 reg. cab,blue w/ extra clearance lights,4x4,T19 4 gear,3.55's,Banks sidewinder w/ K&N, 3.5" straight pipe, 2 gauge pillar, and 3 below dash. Pioneer cd player & a pair of 12" RocFos subs shoved behind seat. Old school tuned Midland 23 channel CB w/ PA and 13 foot whip antenna, Solara DSC marine-band and 4 foot midland antenna hooked too a Delta diamond plate tool box, Aluminum rims,hide-a-ball, RoadMaster drop rear bumper,air gate, and stainless stick on's on the bottom body line.
-93 Ford F250 7.3L IDI Turbo Diesel, ATS upgrades, 4" exhaust and 5" stainless tip, 5 speed, 4wd, 3.55's, maroon on silver, American Racing rims, custom built air gate, DMI rear bumper, extra clearance lights.
-61 Ford Falcon Futura, 289HIPO, T10 4 speed, 9" rear w/ cleveland locker and 3.55's, linelok, Granada front discs.
Mosin Nagant's, K98's, K-31's, Enfields, AK's, and SKS's.
twelve0six is offline
