7.3 idi wont start - Diesel Forum - TheDieselStop.com
post #1 of 11 (permalink) Old 04-23-2011, 06:41 PM Thread Starter
7.3 idi wont start
I have a 92 f250 7.3 idi. It would not start here about two weeks ago and i ended up replaceing the injection pump. It started right up and ran great for 4 days and then it died as i was driving. The motor got quite a bit louder after the new pump was installed. I was wondering if it could possibly be the fuel pressure solenoid?
50deere is offline
post #2 of 11 (permalink) Old 04-24-2011, 12:42 AM
I dont think the idi has any fuel pressure soleniod. You may be thinking of the fuel shutoff soleniod (FSS), check it for current or crack the injector lines to see if fuel comes out as the engine cranks. What do you mean that the engine got louder? Did it surge & get real rough? If thats the case then your sucking air from someplace.
1992 F250 XLT 7.3L ATS 093
Jeff87 is offline
post #3 of 11 (permalink) Old 04-24-2011, 05:44 AM
cdnsarguy's Avatar
My Photos: (109)
Is the selected fuel tank at or near 1/4 tank............... switch to one with more fuel see if problem still remains......
Proud Canadian BOOB man too!!
cdnsarguy is offline
post #4 of 11 (permalink) Old 04-24-2011, 09:59 AM Thread Starter
I meant the fuel shut off soleniod. Ive crack the injector lines as i was cranking it over and im not getting any fuel past the injection pump. When i said the engine got louder it seems like it knocks but at the same time the engine seems to be running smoother if that makes any sense what so ever. When it died it did not surge or run rough before it died. What do you guys think it could be?
50deere is offline
post #5 of 11 (permalink) Old 04-24-2011, 10:55 AM
drinkypoo's Avatar
My Photos: (25)
usually FSS inhibits starting, but if you had a wiring fault to the FSS it could shut off during runtime.
are you getting fuel TO the IP?
Try jumping +12 to the FSS connector (e.g. with a test light) and see if it clicks.
1997 Audi A8 Quattro 225k Warm/Cold packages
drinkypoo is offline
post #6 of 11 (permalink) Old 04-24-2011, 10:58 AM Thread Starter
Ya im getting fuel to the injection pump but not to the injectors. Where is the FSS located?
50deere is offline
post #7 of 11 (permalink) Old 04-24-2011, 11:17 AM
drinkypoo's Avatar
My Photos: (25)
The FSS is the first thing in the IP from the standpoint of fuel flow. It's right behind the inlet from the lift pump. Sometimes they stick if you get enough crud in there.
post #8 of 11 (permalink) Old 04-24-2011, 11:25 AM Thread Starter
So it is the plunger that is just in front of the IP?
50deere is offline
post #9 of 11 (permalink) Old 04-24-2011, 11:44 AM
drinkypoo's Avatar
My Photos: (25)
hmm, now I look again, it looks like it's in the top. here, let me suggest some reading.
Stanadyne Roosa Master
post #10 of 11 (permalink) Old 04-24-2011, 12:01 PM Thread Starter
I will look into the information you gave me and see what i come up with. Thanks for all your help with this problem. I will post if i have any other questions and or concerns thanks again.
50deere is offline
post #11 of 11 (permalink) Old 04-24-2011, 10:10 PM
cdnsarguy's Avatar
My Photos: (109)
There will be a very small amount of fuel emitted at an open fuel line at cranking speed. At idle there would be considerably more and under a higher pressure. Wear eye protection!!!!
