Re: 7. 3 liter injector brass rings stuck
Usually I have found if you take a screwdriver that will just fit in the hole and gently drive it in with a SMALL hammer it will break them loose or then allow you to twist them to break them loose. Something like an EZ-out. You will most likely need to clean up the seats once you get them out so the new washers will seat properly.
1988 F350 CC 4x4 SRW, 7.3 Banks non-wastegated turbo, C6 w/ HD torque converter, Tru-Cool 4590 trans cooler, Highjacker 'softride' 4" lift, pre/post luber, coolant filter, Racor fuel filter/separator, pyro and boost gauges, Progressive 16x8 wheels, 285-75x16 rubber, 3" downpipe into 4" straight pipe over the rear axle and into 5" SS tip. 1994 Alpenlite 33' 5th wheel trailer
