Re: 7.3 liter injectors stuck
I have read on here the procedure is to take one of your old injectors, preferrably one that looks bad, and grind all the threads off the top of the injector where it screws into the head. Then, you screw the injector body back down into the lower half of the injector and keep turning it until it turns the nozzle and gets it to come loose. I'd probably spray some penetrating oil down in the injector hole before I screwed the injector body back in.
1986 F250 2WD Super Cab XLT Lariat w/ 1996 front clip. Dually bed & van rearend (2" wider, allows spring clearance). 6.9 w/ approx 120,000mi. Banks non-wastegated turbo system, Beru ZD1A glowplugs, Delphi BB injectors, Kenworth pyrometer, vac/boost gauge, electric water temp/oil psi/voltmeter mounted in dash. 3" Mandrel-bent open exhaust. C6 trans, 3.54 gears. Okiegringo idler pulley. R134a A/C conversion. WMO/diesel blend in one tank.
