Old 05-11-2007, 09:02 AM   #1 (permalink)
7.3 mating to T-18 part numbers?
Okay, I found a 6.9 to T-19 bellhousing on eBay, and everything I've found says the T-18 and T-19 are identical as far as stick-out, etc.
Now the question:
I need to know part numbers, etc. for the flywheel and clutch. I'm putting a 7.3 to a T-18. I went to Advance Auto Parts, and they have a solid mass flywheel for a 7.3 ($700 less than dual-mass) and an 11' clutch hookup.
The question is, will that work with a T-18, or do we think it is for a 5-speed? Or, will I just have to try it and find out?
Thanks!
1979 F-250 Ranger 4x4. Dana 60 front and rear, 3.53 gears. T-18, NP205. Future show truck with 7.3 IDI.
1999 F-250 Super Duty 4x4. 7.3 PowerStroke, 3.73 gears, 6-spd manual.
hceberha is offline
Old 05-11-2007, 09:46 AM   #2 (permalink)
My Photos: (23)
Re: 7.3 mating to T-18 part numbers?
I'm not sure how well a T-18 will work with our diesels. Keep in mind a T-18 is a non-syncro version of the T-19 (if I recal correctly), and we don't use T-19's. We use T-19B's The B gives us the correct gear ratios.
- Mel
1983 F-250HD 4X4 The Moose Truck - Moose Pump, DPS Injectors, Hypermax Turbo, GV 7spd., 3.54 Gears, Moose Air, RDT, Dual Stacks, 35"tires. My Album 55MPH at 1400 RPM. 19MPG Avg.
1993 F-350 CC DRW The Lady Moose - Hypermax Turbo, GV 9spd w/Double OD. 4.10's. Dual Exhaust, custom trim, turned up 6.9 fuel system, Lucky Flywheel.
1987 Bronco The Moosestang 1987 Bronco Diesel 6.9L C6 4X4 with 3.54 gears, 2" body lift.
HeadGasket/Turbo Article
A BOOB man! Visit EZBoard.com and search for IDI.
agnem is offline
Old 05-11-2007, 10:53 AM   #3 (permalink)
I'm not concerned with the gear ratios. I plan on installing a Gear Vendors trans splitter to give me higher gears. Not to mention the T-18 is already in the truck.
hceberha is offline
Old 05-11-2007, 11:56 AM   #4 (permalink)
Squid63's Avatar
Send a message via AIM to Squid63
I used a Perfection clutch solid flywheel for a 7.3, with a 12" clutch for a 6.9 (1.125" spline) and had the flywheel custom drilled for the pressure plate. Some pressure plates will hit the bellhousing, so check your clearances before starting the engine, or you may be looking for another bellhousing.
I recently did this swap in my '94 with a Ranger overdrive coupled to a t-18.
94 F250 Supercab 4x4, 7.3 IDI Turbo, NV4500 5 speed, 4.10s
95 F350 Crew Cab 4x2, 7.3 DI, ZF 5 speed, 3.55s
Squid63 is offline
» Sponsor Links
»Garage Storage and Cabinets
