Well I finally hooked up our 3000lb trailer, put all my crap in it making it maybe 4000lb (yet it is an enclosed billboard bigness trailer) and I can't believe how terrible it pulled it. Feeling wise it was awesome, made my truck ride better and everything but I could not go over 60, it just didn't have the power. The EGT's regularly got to 1000, I had to floor it up hills and then back down to get the momentum back up. Do all trucks like mine have this issue and thats why you put ZF5, turbos, on it? I would have thought it would have done better than this. There is a truck like mine at work with a 5spd and it gets up a goes a lot faster than mine. I think it may have 4:10 or higher though. I drove it home one night and at 45mph I thought the engine was gonna blow, even in 5th gear. So not sure if this is normal or not. Thanks for the help.
Mine would be the same, but there are a few other things to check, someone smarter than me will chime in and help you out [img]/ubbthreads/images/graemlins/smile.gif[/img] [img]/ubbthreads/images/graemlins/smile.gif[/img].
Bob
My Pictures
1984 Bronco II 4x4 day to day driver : Winter
2005 Explorer Sportrac 4x4 day to day driver : Summer
1991 F350 / Crew cab , Engine 7.3,E4OD tranny. No Turbo but has propane and pyro gauge. The truck is American, complete with a Miles per Hour speedo. Digital trans. temp gauge and voltmeter. Front Captain seats. Control switches for DRL's , Fog lites, High speed idle, Engine kill and scene lites. On board " York " compressed air, Air horns and built in hose reel behind the rear seat. Power bar distribution box from a 1999 Ford Explorer . Checker plate running boards and Frieghtliner mud flaps. LED turn signals in the factory mirrors. DC to AC inverter to run the coffee maker <img src="/ubbthreads/images/graemlins/smile.gif" alt="" /> Soon to be updated with more toys as time & $$$ permit. <img src="/ubbthreads/images/graemlins/smile.gif" alt="" />
They aren't designed to be fast especially with a load on it. If you're after big power you will probably be getting a gasser or a newer diesel. But if you want to spend some time and money on the IDI it can pull real good. A turbo kit would make a huge difference, as would swapping to a 4.10 rear end. But remember such a swap will give you higher RPMs and will cost you at the fuel pump. As Wille said, before you panic, check the fuel and air filters, and beyond that pop testing the fuel injectors and a timing check on the pump might also be in order. If you have two or more bad injectors it might not be a bad idea to change them all. Good luck,
J.D.
J.D.'s Fords: 1986 F-250 6.9 diesel Solid State Glow Plug System 3.55 gears C-6 2WD 178,960 miles.... it still runs pretty good!
Wishlist H-max turbo, T19 tranny,
1989 Ford Ranger ga$$er, non runner, soon to be donated or scrapped!
How many miles on the Injection Pump? When I had mine rebuilt, even before I put on turbo, the new IP made a HUGH difference. Like night and day mucho bettero. OkieGringo
P.S. keep the RPM up above 2600 when pulling up hills/mtns, mine likes 3000 or more and will do it ALL DAY, until it runs outta fuel [img]/ubbthreads/images/graemlins/biggrin.gif[/img].
It did seem to pull better when it was above 2600RPM but does it hurt anything running 3000RPM for 5 hours? I am not sure how many miles are on the IP or if the injectors are good or bad. How do I check all that? It runs fine but it does have a heck of a time in cold weather starting, never wants to start but once it does it is like a brand new engine, plus I have never seen any more than a little puff of white smoke at startup, never had smoke on the highway or anything.
Also, there is a ZF5 in the junkyard across the street but it is a 2WD trans, can you put on a different rear part to make it bolt on to a transfer case or is that all one piece?
Ok, I will test them out. BTW, I noticed you have air bags on your truck, do they make it ride smoother, I hate feeling every uneven part of the road. Thanks.
Well I had to pull that trailer again the same route and this time I ripped off intake tube that the hood seems to cover, I didn't see how this was supposed to work so I took it off. It did better but I think a lot more can be made from this. I am still getting around to the injector pop test but unscrewed the nut on the top of each injector too see if they were all doing something, one of them (the second one back on the drivers side of the truck) made the truck almost die, I think it may be one that works well and the others aren't working as well since it all relied on that injector. I am gonna try and do a ram air setup to help out too. My exhaust is the stock 2 1/2" pipe, I cut off the muffler so I have a straight pipe and I stuck in a glasspack. Would a 3 1/2" make it much better? And my pyrometer is about 3 inches below the end of the manifold in the downpipe, today I hit maybe 1050 but I don't know how high I can go with the location it is in. Let me know. Thanks
There are a number of things that you can do to get the best performance ourt of your truck, and they can make a big difference. I have added a turbo, run 4" exhaust, opened up the air, and then added my propane system. I pull an 30ft 5er that pushes alot of air, and I can run down the road very well. It all depends how deep your pockets are...
89 Ford F250 SC 5 sp 429,100kms, rebuilt drop in at 385,600kms, new clutch and flywheel, Powershot2000 propane, rebuilt ATS Turbo, 4" exhaust with Dynaflow muffler, full Amsoil with single Amsoil bypass filtration, Pioneer DEH-P470 deck and 10" sub with 250 watt amp!!!
I had a 90 non turbo 5 speed with 3:55 before,I thought it was horrible for towing,I would pull a car on my open car hauler and was way dissapointed!! I had to floor it all the time.
I now have a 94 IDI turbo with a full 3" exhaust and some turned up fuel,WOW it tows great!!! I swear it has double the power,I towed this weekend to a mustang swap with my 24 ft eclosed weighing at least 9-10,000 lbs total and the truck did not struggle at all!! I had more pedal but I stayed off it at times to keep egt's under control.never went below 65 mph.
I did the same swap last fall with my 90 non turbo and could not get better than 45 up a hill in 3rd flooring it!!
I say put a turbo on it and go!!!
99 F-250 EXT Cab 4x4 Powerstroke Diablo Delta chip,4" turbo back exhaust, all necessary gauges!
94 f-250 ext cab 4x4 7.3 IDI turbo SOLD!!
94 SVT Cobra #1668
90 f 250 7.3 sold
93 11 sec. mustang 5.0 sold
94 3.8Mustang vert driver sold
80 cj-78 mud toy sold
97 5.0 explorer
You can buy a rear case for the zf to go from 2 to 4 wd sometimes you can get lucky and find the parts you need at a transmission shop, cases and such, if not go online there is a place zf trnsmissions or something like that, I will look it up and post but they are helpful and friendly and will talk with you, I believe they are in Dallas. Hope this helps
1985 F250 w/92 7.3 n/a w/94 zf 5speed
original engine changed with 217000 no problems except glowplugs
original trans changed to get 5th gear no problems with it either
recently changed injector pump and injectors and glowplugs around 475000 have push button controller for glowplugs to eliminate costly controller
