7.3 turbo IDI exhaust - Diesel Forum - TheDieselStop.com
post #1 of 9 (permalink) Old 04-18-2006, 05:04 PM Thread Starter
I have a 1994 Turbo 7.3 IDI I want to put a different down pipe As well as 4" exhaust or bigger. Will any year power stroke match with the IDI as far as down pipe and exhaust?
snocrzy is offline
post #2 of 9 (permalink) Old 04-18-2006, 05:39 PM
patternman's Avatar
Re: 7.3 turbo IDI exhaust
Here's a stainless exhaust on fleabay still no bidders.
(Fine Print)
I am in no way a part of or have any interest in that listing.
90 F350 flatbed dually 7.3 IDI E4OD(self rebuild)
patternman is offline
post #3 of 9 (permalink) Old 04-18-2006, 07:04 PM
no-pipes are diff--and attachment points--
94_turbo is offline
post #4 of 9 (permalink) Old 04-18-2006, 09:11 PM
Unfortunately, you the kit will not work. You could McGyver it to work....everything except the turbo downpipe. You may have to relocate hangers or stuff like that, but no big deal.
Your only other option is to buy a DP from Banks. I bolts right on to the turbo and is 3" outside diameter at the end. From there you can mate it to whatever exhaust you want. I intend on connecting a 3"-4" reducer on the downpipe then going with straight 4" out the back to a 4" mandrel bent tailpipe...no muffler. May need to use a small chunk of stainless steel flex pipe to get around tranny houseing, or get a pipe made up at the muffler shop.
2000 and 2001 Ford F250 Extended Cab, Shortbox Superduties - 7.3L diesel Automatics. Both with less than 87,000 miles.
johnny_munyak is offline
post #5 of 9 (permalink) Old 04-18-2006, 09:57 PM
I took the powerstroke exhaust and made it work for my truck (except the downpipe) needed a few cuts but it wasnt very hard and only took maybe four hours.
1994 F250 4x4 single cab long bed, 7.3L factory turbo, five speed, 165/75/16 BFG comercial ATs, open exhaust, pyro and boost gauge on A-pillar
ntaylor8282 is offline
post #6 of 9 (permalink) Old 04-18-2006, 10:33 PM
I just ordered a 3" down pipe from Stans Headers for a 94 IDI turbo.
"Mekka-lekka-hi, mekka-hiney-ho!"
Ggg6 is offline
post #7 of 9 (permalink) Old 04-19-2006, 08:54 AM
Just curious... I haven't looked... what IS the size of the stock down pipe? 2 1/2"?
Jim
Sandy 1994 F350 XLT RC 4X4, 7.3 IDI Turbo, E40D. Oconomowoc, WI
jslash is offline
post #8 of 9 (permalink) Old 04-19-2006, 09:59 AM
By the time you do the math on the crushed/smashed part, probably about 3/4 of an inch!!! j/k I think it is less then 2 1/2 not by much though.
3 X 06 Ford F250s 6.0 stock 4X4, just got two more, so now 5!
2003 Ford F250 4" Lift, Chipped, 4X4, Diamond Box
2000 Ford F250 7.3 PSD, 4X4, Stock
1999 Ford F350 7.3 PSD, SRW, 4X4, Chipped
1994 Ford F250 7.3 IDIT, 4X4, Pump cranked way up, fuel milage down way low, 6 inch lift on 315/75r16, still rides like a caddy for its day.
And I grow asparagus.
cwatanabe is offline
post #9 of 9 (permalink) Old 04-22-2006, 05:15 AM Thread Starter
Thanks for the tip. I ca;;ed Stans Headers on the web. They make everything I need for my 94 Idi turbo at a very good price i might add.
snocrzy is offline
