Old 03-25-2008, 12:04 AM   #1 (permalink)
Send a message via Yahoo to ia1981dog
Question 7.3 uestions from a newbie
i just purchased a 96 f-250 ext cab long bed 4x4 sat night at an auction, paid 1200.00 for it with 186,000 miles on it. I have a couple of questions, first was it a good deal? now on to the issue, i drove it home, smoked pretty good on start up and for about 15 minutes afterwards, i used the truck to go to all of our easter outings and it died once while idling at a family members house, started right back up, down the road from home it died while sitting at a stop sign started right back up, i now get it to start and then it dies after 1 minute or less, I talked with the owner of it and he says they havent driven it much since last year, they did put new batteries and filter in it last week. he also said it had new injectors last year and it has always been hard to start, i guess i am just looking for suggestions, i was tolp my cam position sensor could be bad or my injection pump ( i didnt think there was one one the 96) it is a turbo, any help would be great.
ia1981dog is offline
Old 03-25-2008, 12:56 AM   #2 (permalink)
cdnsarguy's Avatar
My Photos: (74)
A 1996 would make it a PSD engine........ please try asking your question on the 7.3 PSD forum.......one step up............ Thanks for dropping bye.............
Proud Canadian BOOB man too!!
cdnsarguy is online now
Old 03-25-2008, 10:33 PM   #3 (permalink)
not a ps
actually the 96 is not a power stroke, i have had arguments at the parts store about it because i thought the sane thing.
Old 03-25-2008, 11:17 PM   #4 (permalink)
91diesel's Avatar
Send a message via AIM to 91diesel Send a message via MSN to 91diesel
ORLY(oh, really)???!!!??? I beg to strongly differ. You were thinking right! You need to go back and give that store a smack on the head because the IDI stopped in 1994.5. Powerstroke came out right after that. I have a 1994 powerstroke, many here have 1994 IDI's.
1997 F-350, XLT, dually, crew cab, 7.3 PSD, E4OD auto, B+W turnover goosneck hitch
http://community.webshots.com/user/91diesel
**91diesel AKA anthony2010**
http://www.youtube.com/watch?v=fe622W_yZcQ
16.66MPG
[IMG src=file:///C:/DOCUME%7E1/Owner/LOCALS%7E1/Temp/moz-screenshot-9.jpg][/IMG]
91diesel is offline
Old 03-26-2008, 12:20 AM   #5 (permalink)
M.L.S.C.'s Avatar
How can you tell the difference between the two, short of of looking at the labels on the valve covers and the injection pump timing gear cover? I mean, do the IDI and PSD engines look similar enough to mix 'em up?
The more I drink, the more I drink, the more I drink...
'90 F350 XLT Lariat, reg cab, dually, 4.10s, factory tow package, Chevy hydroboost conversion, P3 brake controller - now Back in Black!
M.L.S.C. is online now
Old 03-26-2008, 06:37 AM   #6 (permalink)
91diesel's Avatar
IDI has hard high-pressure injector lines clearly visible from the top of the engine. The Psd has none. The psd also has no injector pump. The psd's fuel filter is in the middle of the valley, the IDI is a round spin-on on the passenger side of the engine. The psd's intake is just a smaller Y that is bolted to both heads. The IDI actually has an intake manifold. IDI oil fill is in middle front of engine on the ip gear housing, the psd is on the passenger valve cover. Also, you cant see the injectors or the glowplugs on a psd(theyre under the valve cover) on an idi you can see most of them wihtout taking the intake hat off.
anthony
16.66MPG
91diesel is offline
Old 03-26-2008, 08:02 AM   #7 (permalink)
trampsdieseltruck's Avatar
My Photos: (11)
ia1981dog. could it be the fuel pump?put a clear fuel line off the return line on the injector pump and if there are bubbles going throught the line when idle you are getting air in the system
1992 f250 7.3 nonturbo,200k
http://www.youtube.com/watch?v=jxmOuOm9B60
trampsdieseltruck is offline
Old 03-26-2008, 12:10 PM   #8 (permalink)
i also agree. you have a powerstroke DI not a IH Navistar IDI and you could very well have air in your fuel lines! check out the psd 7.3 forum... i hope you have a well stocked bank account! psd's are expensive for parts plus labor in a shop! good luck with your psd!
work truck - 86 Ford F250 with 6.9L Navistar IDI non-turbo diesel 4x4 dana 60 rear, dana 44 front, with 3.54s, C-6 with cooler, manual walbro frb-13 fuel pump, manual motor craft ZD-9 glow plugs, K&N air filter with homemade cold air intake and no soup bowl! napa heavy duty tractor truck batterys, homemade waist oils "conversion" burns everything also runing on B100. working on full work truck set up...
cruzin' car - 94 subaru justy 2 door hatchback 1.2L gas 5 speed everything works!
skunk is offline
Old 03-26-2008, 04:22 PM   #9 (permalink)
cdnsarguy's Avatar
My Photos: (74)
Hey dog post a picture of the engine....... may be someone did some engine changes or fubared the year on you.
Old 03-26-2008, 08:16 PM   #10 (permalink)
sorry guys i do have the psd, however i also run a salvage yard and provide a local shop with cheap parts so in turn my labor is reduced.
Old 03-27-2008, 02:03 PM   #11 (permalink)
Originally Posted by ia1981dog View Post
i run a salvage yard and provide a local shop with cheap parts so in turn my labor is reduced.
well thats a plus!
skunk is offline
Old 03-28-2008, 11:24 PM   #12 (permalink)
powerstrokes can be as reliable and cheap to run as an IDI. Just read through this and the PSD forums and learn.
1995 f350 powerstroke 2wd
1985 f250 6.9l 4wd
dieseltrucker is offline
Old 03-29-2008, 07:15 PM   #13 (permalink)
1992 E350 with 7.3l. is it a IDI or a PSD?
Did Ford put a PSD or a IDI in 1992? This thing has like 256,ooo miles on it. The only reason I would even consider looking at buying this thing is it is an ambulance that was just drove from one hospital to the next its whole life. It comes with a strict matinence record. What would it take to put a turbo on it?
russellfmx is offline
Old 03-29-2008, 11:22 PM   #14 (permalink)
91diesel's Avatar
No powerstrokes in 92. It started in 1994.5 Mine was made in july of 94 so its one of the first PSD's :P
To put a turbo on will take some labor. I wouldnt know,(never done it) but its almost just unbolt old parts and bolt up nice new parts plus some blood and sweat.
Also, air in the fuel lines is not very much of a problem with powerstrokes, now air in oil is as bad as air in fuel. Its easy to purge the psd fuel galleries because the intensifier piston just keeps pushing air into the engine in place of fuel so it will "self prime" in a way.
twon
16.66MPG
91diesel is offline
» Sponsor Links
»Garage Storage and Cabinets
