I'm sure this has been asked by many..... so, I apologize if I'm the bazzillonth person to ask.
The 7.3L IDIs that were installed into International trucks, how different are they from the ones installed into the Ford's? Obviously, the accessories were different, I heard the water pump was different, but aside from those, what was the HP rating and their durability? I saw someone advertising an IH 7.3L IDI out of a bus (IH chassis) and got me wondering......
Has anyone put a 7.3L IDI that was originally in an IH truck into their Ford? Is the basic stripped down engine the same thing??? Or are there 'obvious' differences that would not allow it to be installed?
1999 E-350 Cub Wagon, 7.3L Power Stroke, E4OD, 3.55
1990 E-350 Club Wagon, 7.3L IDI, E4OD, 3.54LS
1983 F-150 2x4, 4.9L, C-6 w/GV-OD, 3.55 Farm pickup
1981 C-8000, 3208 CAT, RT-6510, Rockwell SSHD Tandems (Swap)
1977 K100C, NTC-350, RT-1110, Tandem
1977 Transtar II, NTC-290, RT-9509 Single
1977 Transtar II, Formula 290, RT0-9513, Tandem
1974 C-750, 391CID, Clark 5 speed, Eaton 2 speed
I do believe the oil pan is reversed .....large sump at the front and oil pickup tube is different..... my 2 cents
different exhaust manifolds too, the passenger-side one has the exit on the front bottom end, looks much like an F-series truck driver-side manifold just put on the passenger side. I was actually thinking of robbing the exhaust system off an International truck, as they usually have dual 2.5" piping from the manifolds to the muffler, then a single 4" from the muffler back...
__________________ The more I drink, the more I drink, the more I drink...
'90 F350 XLT Lariat, reg cab, dually, 4.10s, factory tow package, Chevy hydroboost conversion, P3 brake controller - now Back in Black!
Ah, so it's relatively minor issues that could be resolved with exchange of the 'accessories'. So the bell housing is the same then??? Or is the truck ones using some kind of SAE housing?
Oil cooler is different too. Also on a bus the injection pump would generally be goverend down to about 2700-2800 rpm tops in most cases , I would imagine there is a difference in the injectors to match the torque curve of the pump.
'92 F-350 7.3 5 spd, Crew Cab dually,ATS turbo, 4" Exhaust, Air seat, Western Hauler bed. My Gallery
You would see LESS power out of a truck / bus motor since the rev limiter is set much lower. The IDI V8's were the "economy" engines in Internationals, and were just enough to get the job done.
