Old 04-18-2007, 08:38 PM   #1 (permalink)
Bill1013's Avatar
7.3L IDI Oil leaking #8 Cyl.
Org. Problem [img]/ubbthreads/images/graemlins/depressed.gif[/img]Post #s 3294503 04/02 & 3299706 04/07 Finally got to road test today. Started engine-Metalic knock at #8-pulled injectors at 6 & 8 DRY Pulled GPs at 6 & 8 OK. Pulled rocker cover, everything OK there. When speeded up knock disappears. Drove 1/4 mile all of a sudden blue smoke like Heck drove another 1/4 mile turned around drove home total 1 mile driving. Temp. normal- coolant in radiator was cold probably just before thermo opened - started engine back up - exhaust smoke blue - smoke behind engine oil dripping on exhaust SHUT HER OFF - 5" spot of oil in driveway. Oil is coming from bottom of head gasket predominately at 6 & 8 -- 2 & 4 is dry. WHAT NOW ? [img]/ubbthreads/images/graemlins/shrug.gif[/img] [img]/ubbthreads/images/graemlins/sick.gif[/img] [img]/ubbthreads/images/graemlins/vomit.gif[/img] [img]/ubbthreads/images/graemlins/vomit.gif[/img]
OLDBULL and TEARS [img]/ubbthreads/images/graemlins/depressed.gif[/img]
99.5 F350 XLT Lariat 4X4 AT 4.10 DW CC LB Centurion conversion Garret Turbo Radio SD & Tape 126,700 03/08 Build date 03/99
Rebuilding engine. 92 F350 7.3 IDI CC LB dually Banks turbo US Gear O/U ENGINE IS SHOT !
1990 F350 XLT Lariat 7.3L IDI E4OD Dually 280K+ 2WD
Reman Promar Long Block 11/07
Reman IP - New Delphi Injectors Beru GP's New radiator & hoses New WP
Dual Exhaust 3"X18" resonators
Soup bowl gone, 4" intake W/AZ filter
Cobra CB W/Weather Interrupt - Dual Trucker Antenna's
Blk. Grill W/Brush Guards - Fog lights - Rally driving Lights. GN 20K & Reese 16K 5er hitch
http://community.webshots.com/user/oldbull8?
Formally OLDBULL
Toys: 1984 Coachmen Leprechaun F350 Chassis 460CID 92K miles.
30 ft. Jayco Jay Designer 5th wheel.
Have AutoEnginuity W/Ford enhanced. Lima OH area.
My mind works lightening fast.
One flash and it's gone.
Bill1013 is online now
Old 04-19-2007, 01:12 AM   #2 (permalink)
arthurgoboom's Avatar
Re: 7.3L IDI Oil leaking #8 Cyl.
Try retorquing the headbolts in that area and see if they pulled the threads or the gasket squished down and is loose now, or something or other?
1986 F250 2WD Super Cab XLT Lariat w/ 1996 front clip. Dually bed & van rearend (2" wider, allows spring clearance). 6.9 w/ approx 120,000mi. Banks non-wastegated turbo system, Beru ZD1A glowplugs, Delphi BB injectors, Kenworth pyrometer, vac/boost gauge, electric water temp/oil psi/voltmeter mounted in dash. 3" Mandrel-bent open exhaust. C6 trans, 3.54 gears. Okiegringo idler pulley. R134a A/C conversion. WMO/diesel blend in one tank.
arthurgoboom is offline
Old 04-19-2007, 03:27 AM   #3 (permalink)
cdnsarguy's Avatar
My Photos: (74)
Do not panick.........sent email.
Double check the rocker cover bolts for starters.......
There is also a possibility of a precup being loose..... ask your mechanic who did the valves did he remove the precups and did he reinstall in original holes.........
Proud Canadian BOOB man too!!
cdnsarguy is offline
» Sponsor Links
»Garage Storage and Cabinets
