This might be a stupid question. I’m trying to sell my truck and when I checked the VIN number it says I have a 7.5 liter diesel and not a 7.3 diesel. So my question is what is the different between the 7.5 and the 7.3? Is the 7.5 better or worse? [img]/ubbthreads/images/graemlins/confused.gif[/img]
02 F250 4x4 7.3 / 3.73 gear stocked Crew Cab Long bed.(187050 miles on her) SP diesel exhaust brake and TC lock.
I own a 7.5L (460) gasser F-250 and I have driven a 7.3L IDI F-250 about a year ago. From what I can tell the 460 has more power than the IDI and IDIT (drove one of those too a while back). The only true difference I can say is that the 7.3 gets a lot better mileage than the 460.
<font color="blue">2005 National 2nd Place Winner in Agricultural Mechanics in Repairs and Maintenance for The National FFA Organization.</font>
Traded in: 1995 Ford F-250 XLT Super Cab Longbed 4x4, 460, auto, 3.55's., K&N filter, glasspack duals. Miss everything about this truck but the gas mileage....
Some days you're the dog.....Some days you're the hydrant.
7.5 is a 460 gasser. The big differences (aside from gas vs. disel) the mileage stinks with the 460, that and the 7.3 diesel will go many, many more miles before it needs to be rebuilt. Heck my dang 5.0 gasser only gets 10mpg on the highway. I cannot imagine the mileage of the 7.5. [img]/ubbthreads/images/graemlins/eek.gif[/img]
Heath
__________________ 1986 F250HD 4x4 7.3L IDI '95 PSD front clip, '97 bed, T19, D60/10.25 with 3.55's. Rebuilt from the frame up. Banks Turbo, DPS IP & Stage 1's, Isspro TTM, Banks Exhaust, Boost gauge, Pyrometer, Precharged Coolant Filter, Holley Red Pump. 16.5 x 37 x 12.5 Goodyear Wrangler's, Air Horns. 6in lift, Fresh Paint, On-board Air. Revamped Interior. Rhino Liner.
This is not to compare the two engines. I think what you have just dicovered is (assuming you are not the original owner) that a previous owner changed the engine before you got it and did not disclose this to you. The good side is that you ended up with a much better engine than you would have had. I would think that this will provide a higher resale value (even though it is not original). I know I was bound and determined to find a diesel. If it was a gasser, I wouldn't even go look at it.
1991 E-350 7.3L in Born Free Motorhome / Showroom.
Heath
Yep,
Got an 85 with a 460 ga$$er punched .060 and she gets 8mpg runnin' empty or fully loaded! [img]/ubbthreads/images/graemlins/eek.gif[/img]
Goldie 1990 F-350 Custom 4x4 C/C DRW conversion. 7.3L Banks non-waste gated turbo, ZF-5 with 4" custom Exhaust complimenting a RDT venturi system, Autometer Pyro and boost 2 gauge pillarpod and your standard compliment of mechanical gauges. Clutch pedal Heim joint mod.
The Beef 1989 F-350 Lariat C/C DRW 7.3L N/A, ZF-5. Clutch pedal heim joint mod. Original price $500.00.
Currently slated for an extreme makeover ground up restoration.
Mater 2007 F-250 Lariat 4x4 6.9L IDI, T-19 trans pushing a 7'6" Western plow. Completely assembled from the tires up!
Thanks for the help. Yes, you are correct I'm not the original owner when I bought the truck it had 62000 miles on it now it's at 82450 and still runs good. It just has a strong diesel smell to it.
The 89 f 250 excab with injected 460 would get 6 around town and 16 on the hiway, averaged out to about 9 [img]/ubbthreads/images/graemlins/eek.gif[/img]. thank god I sold it long ago. [img]/ubbthreads/images/graemlins/warmsmile.gif[/img]
1994 F350 crew cab Dually 2 Wheel Drive 7.3 IDI, E4OD,factory turbo. just purchased april 2003, did rebuild ( rings and bearings )may 2003, Ready to start adding extras!!!
My '91 F-150 with 302 got 7mph pulling a 3000 pound trailer.
14 on the highway.
My F-350 with BIGGER diesel engine, more weight, and more wheels gets 17.6 on the highway... actually probably more. Can't remember if I factored in the odometer error--indicated 0.91 miles per actual mile traveled (91 miles indicated per 100 actual miles).
- SOLD: 1991 F-350 XLT crewcab, dually. BTS E4OD. My favorite truck.
- NEW DAILY DRIVER: 2006 Ram 3500 SLT quad cab. 5.9L Cummins, 6-speed manual transmission, nav system, Jake brake. No mods, now or ever. 100% satisfied.
wich has more torque ive been itchin to hook up to my buddy who has a 460 under the hood and pull hima round teh parking lot put i dont want to be embassesed and me get pulled around!
-JEremy Roooster!
American by birth, Southern by the grace of God!
1991 F250 7.3l 200XXX extended cab long bed. 3.55's REDNECKED OUT!! 295/75/16 Bfg All Terrains 16 in billet rims. New front brake pads and rotors, rear shoes, glow plug controller, glow plugs, return line kit duralast batteries, mitubishi off set gear redution starter, altenator, valve cover seals, holley red pump,new injector pump, soon to be new injectors, new vacum pump. Removed soup bowl and drilled holes in air intake.
My '86 460 definitely has enough power to do any thing I want but my turboed 7.3 would rip that 460 truck apart. Now hooking my 7.3 to my 500 cadillac powered Chevy dually would be fun. [img]/ubbthreads/images/graemlins/biggrin.gif[/img] I don't think I have a chain that wouldn't break.
Keith
2000 F350 Cab/Chassis CrewCab 4x4 DRW 7.3/auto "Hamilton Custom Cruiser Conversion" WesternHauler Bed 50gal TFI transfer tank 4" turbo back Exh. DIY intake w/Napa 6637
'88 F350 CrewCab SRW 4x4 7.3/C6/4.10LS Banks non-wastegated turbo NAPA 6637 airfilter 4" lift Airlift rear airbags 107k miles
'86 F250 ext cab. 4x4 6.9/C6/3.55 arrowcraft dually conversion 45gal aft tank ?53k miles
'85 F350 Cab/Chassis DRW 55" Schwalbe Sleeper 7.3/T-19, 4.10, Banks Sidewinder wastegated Turbo Holley red tweaked inj.pump 6.2 governor and STACKS! The old 6.9 gave up after 445k miles.Stacked before stacks were cool since 5/85 **SOLD** My Pics
'86 F350 Crewcab Dually 6.9/C-6/4.10 LS Racor seperator. 233k miles **SOLD**
'89 F350 Crewcab SRW 4x4 7.3/zf5/4.10LS 193k miles**SOLD**
I wouldn't be surprised if the -peak- torque on the 460 was the same as the IDI. But the HUGE difference with a diesel is that you can get almost full torque all across the rpm range; including all the way down close to idle. The torque-curve for most diesels is almost flat.
Gasser torque-curves, on the other hand, have a pronounced 'hump' shape. They have terrible torque at low rpm's. At 1,000 rpm, I doubt the 460 has more than 200 ft-lbs output; whereas the 7.3 is probably 300+.
That high torque even at idle is what makes a diesel stick so easy to drive. You almost have to -work- at it to stall a diesel stick...not that I haven't done it once or twice...
My other diesel is a...
Hydra 35-ton Excavator, 6V71T; Isuzu C201 genset;
'71 VanPelt Pumper, Cummins 855 Turbo
There used to be a link here, to some useful IDI-diesel tech info; but it was chopped out by others, in a vain attempt to repress the very essence of the internet: linking!
sigh...
The EFI 460 made peak torque 410lb. ft. @ 2200rpm. I'd say it has pretty good low end.
-JEremy Roooster!
Actually it depends on who breaks traction first. If you start spinning he will be dragging you around.
Don't let the 460 fool you--it is not the gutless gasser that many think it is. I have seen a 460 take out a stock '96 Cummins with no trouble at all.
The 460 is good for about 200,000 miles if well maintained. I have seen a few make it to 300,000 but at that point they are extremely tired. That is one advantage to diesel.
I can't say that the non-turbo diesels have better value than the gas trucks, its basically a toss up between the IDI and 460, but its obvious that the PSD trucks do hold value better.
I have both on good day the 460ci 7.5L with now 205,000 miles on the ticker gets 12 mpg with dually wheels on it and 3.75 gears. And for some reason my 7.3L IDIT turbo runs circles around it and gets around 16MPG with 202,000 miles on the ticker I have owned both since new.
Unfortunately though I do have to say the 460 has cost me a lot less in repairs, even considering tune ups. And it eats a lot less transmissions than my diesel!
1994 7.3 I.D.I. Navistar 444 CI
ATS Factory TURBO E4OD Red On white Crew Cab DRW 4:10 w/ AUBURN LIMITED SLIP
3" ATS Exhaust and turbo housing, Banks Trans Command, calibrated pump, K&N filter, Gruss style coolant filter, 203K+MI not a lick of trouble with the motor. now on 16th trans. 10 under factory 100K mile warranty
Alpine CVA-7878 XM radio 6cd changer 3 8" phoenix gold subs 75x4 Sony mobile ES gold 4ch amp, Sony 500W 1ch amp MB quart components in Q forms kick panels. 1 farad cap.
Pro car parts jewel cut headlamps and turn signals
APC clear cab markers, suvlights.com harness silverstar bulbs and L.E.D.'s in the fenders. IT's paid for and its MINE!
Family Toys and tools,
00'F350 psd CC Drw 2wd Bright Amber Western Hauler
SOLD 01' Peterbilt 330 4Dr. Texas trucks conversion cAt 350hp
02' Psd Excursion Limited ultimate Estate Green helliwig swaybar 101K miles
1996 fetherlite 4 horse GN, 2003 sooner 6 horse GN with midtack
