88 f450 running issues - Diesel Forum - TheDieselStop.com
Old 11-20-2009, 07:40 PM   #1 (permalink)
I have a 1988 f450
I am having major running issues after warming up
the truck runs great for about 45 minutes
after that it starts to lose power and spit and sputter
exceesive white smoke , especially on deacceleration
pedal becomes very jerky
I have replaced the fuel filter , fuel transfer valve , fuel pump and drained and cleaned both tanks.
Any suggestions
thanks in advance
tmygib is offline
Old 11-20-2009, 08:37 PM   #2 (permalink)
NH2112's Avatar
Send a message via MSN to NH2112 Send a message via Yahoo to NH2112
Does it start right up when hot? If not, try either pouring a quart or 2 of engine oil in the fuel tank or pouring lukewarm water over the injector pump. A worn pump can cause issues like you're having, the engine oil increases the fuel's viscosity and the lukewarm water will tighten up a loose pump enough to verify the problem.
Phil
1988 F350, NA 7.3l, 5-speed, crew cab, 4.10 SRW. Miles: over 450K. Being taken off the road within the next month or so to deal with advanced rust. May just do a resto/rebuild to better my bodywork & paint skills.
NH2112 is offline
Old 11-20-2009, 09:04 PM   #3 (permalink)
Check your fuel hose from the tank to the lift pump. I had one that would run great until the fuel hose near the exhaust heated up. Once the hose warmed up and softened, the lift pump would suck it flat under heavy loads. I replaced it for a couple bucks and it ran fine after that.
Wakawaka 'cause that's what it sounds like
1991 E350 7.3 IDI E4OD
1986 E350 6.9 C6 dually box
wakawaka is offline
Old 11-21-2009, 02:34 AM   #4 (permalink)
rsr911's Avatar
X2. Mine did the same but I was running veg blends at the time. I swapped to an electric pump but a new hose would have fixed the problem.
1986 F350 Crew Cab 2wd SRW. 1991 7.3 IDI, T-19 4spd Sterling 10.25 3.55, 12" HD clutch. A Banks waste gated turbo. 5" cut down Peterbilt stack. Midwest rebuilt IP turned up. AC Delco 6.5 GM 12V GP's, working great. Running W85 high performance zero-gel diesel! D60 front conversion, 4wd conversion, dually conversion, and steel flatbed conversion now underway. Man those frame rivets are a pain!
1966 Porsche 911. 1983 911 SC engine with modified Zenith carbs, headers, 911S brakes, custom fuel rails, MSD 6al box with timing computer, 1974 IROC body kit. 1850lbs, 200rwhp, total blast to drive.
rsr911 is offline
Old 11-21-2009, 06:12 AM   #5 (permalink)
Thank you for the input , I am out of town until Monday. I will check the fuel lines then and let you know. Thanks Again
tmygib is offline
