Old 03-23-2008, 04:03 PM   #1 (permalink)
89 7.3 IDI Valley Pan Plug
Does anyone know anything about the plug in the valley pan that is directly behind the down tube for the CDR valve and underneath the glow plug controller? I am new to Diesels and going over the engine in this truck. This plug has a 3/8 ratchet (square) hole that I am assuming should have a bottom. The plug on my truck appears to be rusted out or something because you can see through the bottom of the square hole and it appears that I can see into the space where the CDR downtube also goes. You cannot see into the lifter valley but it definitely goes below the plug. Should this plug be like this? I tried removing the plug but it will not budge. What is this plug for and should it have a solid bottom? Any help would be greatly appreciated. Thanks
capt324 is offline
Old 03-23-2008, 08:25 PM   #2 (permalink)
suv7734's Avatar
The plug does have a hole all the way through. It drains into a passage that exits at the rear of the block. That way any fluids that build up in the valley pan wil drain away.
1988 F350 CC 4x4 SRW, 7.3 Banks non-wastegated turbo, C6 w/ HD torque converter, Tru-Cool 4590 trans cooler, Highjacker 'softride' 4" lift, pre/post luber, coolant filter, Racor fuel filter/separator, pyro and boost gauges, Progressive 16x8 wheels, 285-75x16 rubber, 3" downpipe into 4" straight pipe over the rear axle and into 5" SS tip. 1994 Alpenlite 33' 5th wheel trailer
suv7734 is offline
Old 03-23-2008, 11:35 PM   #3 (permalink)
Yes... Its just as posted above but... When any fluid in draining thru it the fluid will run down the bellhousing and drip off the starter area. It really makes a big mess but its really needed. Ford no longer makes these plugs. I bought about 12% of what Ford had left. I got 10 of them.... Spares are always good to have...
icanfixall is online now
Old 03-26-2008, 01:03 AM   #4 (permalink)
And if you do need to get it out its in there REALY tight, just rebuilt my 7.3 and I thought I was goint to break something breaking it free, think its got some kind of thread sealer/adhesive on the threads.
-Rob
'94 F250 XLT 7.3L. Turbo Diesel 4X4 "OFF ROAD" package, X-Cab, 4.10 grears, Now a 5 speed, original IP, just did injectors,"Wallace mod" 3.5" turbo outlet housing and 3.5" DP and straight piped exhaust, 113K on the clock. Repainted it black. Ispro pyro and boost gauges, turned up pump.
ClassicFordGuy is offline
» Sponsor Links
»Garage Storage and Cabinets
