89 F-350 Won't Start... Fuel? - Diesel Forum - TheDieselStop.com
Old 05-28-2009, 02:34 PM   #1 (permalink)
Hey everyone! I bought an 89 U-Haul with 33K on a rebuild. I've had it for about 2 months and have put about 300 miles on it. I noticed one day as I went to start it that it had a hard time catching after it sat in front of my storage unit, tilted to the right, for about 6-7 hours. I brought it home where it sat for about 10 days. It was slow to start and after a few seconds it died and won't start. I can spray squirts of starting fluid into the air cleaner and it fires. I replaced the fuel filter and still no go. I am versed in gasoline but have never worked on a deisel. Some guidance geared toward a layman would be greatly appreciated. I'm assuming the pump but want to do the tests necessary to get an accurate diagnosis and I need to do the work myself
Steve
NuuMee is offline
Old 05-28-2009, 05:02 PM   #2 (permalink)
fro
Steve
Just a heads up,starting fluid in a diesel engine will cause extreme engine damage
94 F250 IDI turbo e40d with 367k on her.
Hypermax exhaust,cowl induction hood and AFE air filter added
Vegas baby!!
fro is offline
Old 05-28-2009, 05:10 PM   #3 (permalink)
Snotzalot's Avatar
In a diesel using glow plugs!
Regards,
Paul - Pocono Mtns. USA
02 E350 15 Passenger, 52,000 Miles
'90 E350 7.3L Ex-Ambulance High Top 400K Miles, No Turbo, Stock Stock stock, No ELC! (Extended Life Coolant) & 10 Oz. Bars Stop Leak, Retired 11/8/2011 with blown trans.
7.3L Alternator Belt Idler Photos
Snotzalot is offline
Old 05-28-2009, 05:11 PM   #4 (permalink)
Snotzalot's Avatar
Did you bleed the fuel filter? Are the rubber caps and return lines leaking diesel from around the injectors? It's most likely NOT the injection pump, but it may be the "lift pump" aka as a fuel pump on a gasser and located below the alternator on the side of the block.
Regards,
Old 05-28-2009, 07:35 PM   #5 (permalink)
Fuel Issue
Hey Fro! Thanks for the heads up! I was told to do 1 second squirts just to see if the problem was elec or fuel related. And I was given that instruction at one of your competitors forums by one of the senior members who's been in deisels his whole life. He did say not to do very much and that it technically was not good in larger quantities. I'm sure there are better ways to accomplish the task and I certainly will keep your correction in mind.
Now... how do I go about determining the culprit here and doing the repairs? I'm thinking it is the lift pump. Where do I start? Thanks everyone!
Steve
NuuMee is offline
Old 05-28-2009, 07:41 PM   #6 (permalink)
Snotzalot's Avatar
I asked you two questions, you can start by answering them.
Regards,
Old 05-28-2009, 10:02 PM   #7 (permalink)
trampsdieseltruck's Avatar
My Photos: (33)
do a vacuum test on the fuel pump
1992 f250 7.3 nonturbo,4x4 360,000km,auto tranny
trampsdieseltruck is offline
Old 05-29-2009, 01:18 AM   #8 (permalink)
Diesel dont have vacumn
MECHANIK19 is offline
Old 05-29-2009, 03:49 AM   #9 (permalink)
89 Fuel Issues?
Snot, How do I bleed the fuel filter? I cranked the motor hoping to pressurize the system and then pushed on the valve core at the filter... no pressure. The fuel pump looks brand new. No leaks at the injectors and the ignitors look brand new as well.
Tramp, how and where do I check the fuel pump for pressure?
Thanks guys! I DO appreciate it!
Steve
NuuMee is offline
Old 05-29-2009, 07:20 AM   #10 (permalink)
Snotzalot's Avatar
Press the schrader valve on the top of the fuel filter while the engine is being cranked over. Did you fill the fuel filter before installing? Don't even try to fill an empty fuel filter by cranking the motor over.
Regards,
Old 05-29-2009, 07:22 AM   #11 (permalink)
Snotzalot's Avatar
The lift pump does on the inlet side, that's what was being referred to.
He needs to properly bleed the fuel filter before he does anything else.
Regards,
Old 05-30-2009, 01:44 PM   #12 (permalink)
Fuel Issue
Ok, I primed the fuel filter and had a friend crank the engine while I held the shrader open and... nothing. I also disconnected the fuel line from the pump to the filter and held my thumb over the line while cranking... zero. Next?
Thanks, by the way
Steve
NuuMee is offline
Old 05-30-2009, 08:34 PM   #13 (permalink)
Snotzalot's Avatar
You need a lift pump. $40 USD.
Regards,
Old 06-01-2009, 02:16 AM   #14 (permalink)
89 Fuel Issue
Thank you Snot
Steve
NuuMee is offline
