Old 03-28-2008, 10:51 PM   #1 (permalink)
89 F350 transmission id
Hi,
Trying to figure out what automatic transmission I have in my 89 F350 crew cab dually, 7.3 diesel and if the tach affects the trans operation.
vin 2ftjw35m5kca22961
It feels like a 3 speed automatic. At 50 I am looking for it to go into another gear
neumann is offline
Old 03-28-2008, 11:27 PM   #2 (permalink)
NCheek's Avatar
The trans code should be listed on the door panel sticker, VIN doesn't say anything about the transmission.
-Nick
My Daily Driver:
1986 F-250 2WD, Regular Cab, LWB, 6.9, T-19, Sterling 10.25", open 3.55's, XLT Lariat, Texas Sesquicentennial Limited Edition, No Restrictor Plate, manually switched high idle/advanced timing, and an awesome custom shift knob thanks to Bruce Roosa / Koolknobs.
279,000 miles and counting, hoping for a US Gear OD and a Hypermax Turbocharger one day.
My first truck:
1982 F-250 4WD, Extended Cab, LWB, 5.8, C6 to T-19 swap, BW 1345, Dana 44 TTB/Dana 60 Semi Floater, open 3.55's. About four different colors (not counting rust), currently on loan to my little brother. Maybe one day it can be home to a 6.9L too.
Work Truck:
1992 F-700 Flatbed w/ dump, 7.0L BIG BLOCK GASSER, 5-speed trans (Clark?), 26,000 lb GVWR. Rides like a tank
NCheek is offline
Old 03-28-2008, 11:32 PM   #3 (permalink)
trans code of "K"
neumann is offline
Old 03-28-2008, 11:40 PM   #4 (permalink)
NCheek's Avatar
It's an E4OD 4-speed auto with overdrive. It think that the shift points are determined by RPM, but I'm not sure. Someone else will chime in with all the details.
-Nick
My Daily Driver:
My first truck:
Work Truck:
NCheek is offline
Old 03-28-2008, 11:43 PM   #5 (permalink)
7.3L F-250's Avatar
My Photos: (16)
Send a message via AIM to 7.3L F-250
shift points on the E4OD go off of RPM and MPH
-Tj
RIDES
1987 ford F-350 xlt lariat, full leather interior, 7.3L idi, banks turbo, E4OD, MBRP muffler, 6" lift, 38" superswampers for summer, 35" BFG all terrain for winter, bronze pearl paint
CURRENT PROJECTS
1979 ford F-350 custom 351m C6
soon to get a 7.3idi, banks waistgated turbo, ZF-5, 6" lift kit, Saphire blue paint, auto meter colbalt gauges, and much more
WANTS A
2008 ford F-250 XLT with a 6.4L and a zf-6
7.3L F-250 is offline
Old 03-28-2008, 11:45 PM   #6 (permalink)
Looks like I have a C6....door jam code says letter K
FORD F SERIES 2WD AT
7.3L/445 Diesel
1988/89
C6
7t speedo drive, ID # PJE-G1, L / L1
E9TP-7000-AYA
8t speedo drive, ID # PJE-J, K / K1
E9TP-7000-AVA
neumann is offline
Old 03-29-2008, 12:04 AM   #7 (permalink)
I feel you have the E4OD but look at the injection pump. If it has an electric switch on the drivers side with 3 wires to it then you have the E4OD. Now if it has a vacuum switch on that side its the C6 trans. Also the sides of the trans case will say E4OD cast into them.
icanfixall is online now
Old 03-29-2008, 12:29 AM   #8 (permalink)
cdnsarguy's Avatar
My Photos: (74)
I think you will find a C6....... it is a medium trans size. The E4OD has external reinforcement webbing on the trans and is way larger.......
Proud Canadian BOOB man too!!
cdnsarguy is offline
Old 03-29-2008, 01:29 AM   #9 (permalink)
M.L.S.C.'s Avatar
Those two yes, but also the FIPL/TPS.
Easiest way to figure out the tranny is looking at the shifter indicator and also the dashboard:
a) P-R-N-3-2-1 -> you got the C6
b) P-R-N-D-2-1 and an OD button on the dash to the right of the steering column -> you got the E4OD
The more I drink, the more I drink, the more I drink...
'90 F350 XLT Lariat, reg cab, dually, 4.10s, factory tow package, Chevy hydroboost conversion, P3 brake controller - now Back in Black!
M.L.S.C. is online now
Old 03-29-2008, 08:02 AM   #10 (permalink)
It has a module on the driver side of IP with two large vac lines, PRND21 with no overdrive button to be found
neumann is offline
Old 03-29-2008, 09:51 AM   #11 (permalink)
Mark Kovalsky's Avatar
Trans code K is C6. Trans code E is E4OD.
Mark
Mark Kovalsky is offline
» Sponsor Links
»Garage Storage and Cabinets
