89 ford truck instrument panel ground - Diesel Forum - TheDieselStop.com
Old 11-01-2009, 05:13 PM   #1 (permalink)
ColLonewolf's Avatar
Been having gauge problems for some time now (inop tach, and fuel, eratic temp and the usual oil). Figured I could use a better ground. When I removed the gauge cluster there was no indication as to where I could put a ground wire. Has this been addressed before? Any help on this would be greatly appreciated. Thanks.
1989 Centurion Classic 350 4X4 (F-350 4door Bronco), W/93 7.3L IDI non-turbo, ZF 5-Speed(LUK)/BW 1356/Dana 60/Sterling 10.25, 3.55, Hypermax Turbo/Intercooler, 3 1/2" Exhaust/Pyro(inop), RDT, 265/75R16 BFG/AT on 16X8 American Racing Wheels 138K and still going strong
1983 300SD Turbo Diesel, 3.0L Inline 5, 4 Speed Auto, White/Parchment, VDO Boost Gauge, 215/60R15 Bridgestone Potenza RE960AS Pole Positions on 15X7 15 Hole Wheels, Straight Piped, 298K?
ColLonewolf is offline
Old 11-05-2009, 02:28 PM   #2 (permalink)
So it seems as if I have stumped ya. So in that case does anyone know which wire or wires are for the ground in the harnesses on the back of the pannels?
Old 11-05-2009, 05:19 PM   #3 (permalink)
cdnsarguy's Avatar
My Photos: (109)
Col I will try and email a pic to you...... it is of the 90 dash but most likely the same.
There appears to be at least 6 grounds from instruments on the cluster so there should be at least one major point of contact. IIRC you have the flexible sheet with copper inlay for the power and ground contacts....
Sorry I do not have your email addy PM it to me.........
Proud Canadian BOOB man too!!
cdnsarguy is offline
