'89 IDI 7.3 not starting - Diesel Forum - TheDieselStop.com
post #1 of 6 (permalink) Old 11-06-2013, 08:56 PM Thread Starter
skiprrr's Avatar
Hey Everybody,
Ive got a 1989 F350 7.3 IDI 2WD that up until recently, was starting just fine. I did a one day 900 mile trip from Tucson to Las Vegas to pick up a welder, and it seems like the trouble started after that. So far I have:
- Installed two new 850 CCA batteries
- Cleaned up all of the grounds and replaced battery cable ends
-Put a new solenoid on it
-Checked the glow plugs with a meter, all dead nuts at 3K ohms
-New fuel/water filter
The starter, I am not sure if it is okay; I know it is supposed to be spinning a minimum of 200RPM, but I have no way to check it. Took it to an Autozone today, inconclusive (and a waste of time)
My WTS light stays on when I try to start it for about 10-12 seconds, but one thing I did notice was I hear no clicking from the controller like I am supposed to, and the volts gauge on the dash does not deflect (when it is supposed to click)
Oddly enough, sometimes Ill take my battery charger after I try to start it once or twice, hook up the battery on the passenger firewall(in engine start mode), and it starts! Sometimes that works, but not always.
Any thoughts? I need to get my rig running again
skiprrr is offline
post #2 of 6 (permalink) Old 11-06-2013, 10:21 PM
chuckster57's Avatar
Take the batteries off and load test them. I have seen new (off the shelf) batteries fail. You may not get the GP's cycling after the truck has been started once for the day.
Train Horns:
PM please not visitor message
chuckster57 is online now
post #3 of 6 (permalink) Old 11-07-2013, 09:57 AM Thread Starter
skiprrr's Avatar
Yes, I did that already. Guess Ill put a meter on the controller relay today and see what is going on there. Now that I think about it, I have never heard any clicking from the GP controller.
I talked to my step dad yesterday (he used to be a diesel mechanic) and he told me "not to worry" about the glow plugs, as I live in Arizona, and even now the temps are usually about 70-75 degrees when I try to start it...I am not so sure about that, though.
skiprrr is offline
post #4 of 6 (permalink) Old 11-07-2013, 10:12 AM
drinkypoo's Avatar
My Photos: (25)
Even when the temps are in the 100s, the truck starts much easier with glow than without.
1997 Audi A8 Quattro 225k Warm/Cold packages
drinkypoo is offline
post #5 of 6 (permalink) Old 11-08-2013, 10:52 AM Thread Starter
skiprrr's Avatar
yes, that is what I thought. I took one of the plugs out yesterday and cycled them and no heat at that plug. So I took a look at the controller and one of the big lugs on it was loose, like it was broken off inside so I didn't even bother to test it, I ordered a new one...keep my fingers crossed and hope that's it
skiprrr is offline
post #6 of 6 (permalink) Old 11-09-2013, 06:55 AM
NH2112's Avatar
Send a message via MSN to NH2112 Send a message via Yahoo to NH2112
Did you ground the plug body?
Phil
Check my lists of common part numbers in my photos! Updated often!
1991 F350 Lariat XLT, 7.3l, 5-speed, crew cab, SRW, 3.55, 2WD.
1990 Jeep Wrangler Sahara, in the process of a major overhaul/upgrade. OM617 on the horizon! Front & rear Dana 44s from a Wagoneer till I get some 1-ton axles built & narrowed, and eventually a front shackle reversal. Diesel YJ, bay-BEE, and not a cookie-cutter 4BT conversion!
NH2112 is offline
