89 nails, and rattles and cold start-ups - Diesel Forum - TheDieselStop.com
Old 11-19-2009, 04:26 PM   #1 (permalink)
My 89 F-350 4x2 all stock. At cold start-up it will sometimes rattle or I think what you call nail for about 10 -15 seconds. I do always use diesel kleen additive just for the extra lubraticity. Is every thing allright it has been running fine except just a split second squirt of ethyer at cold start. Have changed all glow plugs motercraft.
lunas jackel is offline
Old 11-19-2009, 05:41 PM   #2 (permalink)
Snotzalot's Avatar
Does it fire when you first crank it the die?
If your GP's are good and the GP relay is working, your start problems might be a bad/slow starter, weak batteries, bad battery cables or terminals. Using starter fluid with a working GP system is dangerous.
Regards,
Paul - Pocono Mtns. USA
02 E350 15 Passenger, 52,000 Miles
'90 E350 7.3L Ex-Ambulance High Top 400K Miles, No Turbo, Stock Stock stock, No ELC! (Extended Life Coolant) & 10 Oz. Bars Stop Leak, Retired 11/8/2011 with blown trans.
7.3L Alternator Belt Idler Photos
Snotzalot is offline
Old 11-19-2009, 06:20 PM   #3 (permalink)
Just replaced starter so strong start. and realay is new can hear it click . Two new good batts. New alt.New plugs . But this post I wanted to know about the nailing at cold start for 10 sec. I think It is injection pump for the first few seconds. Juust wandering if might be getting tired.
Old 11-19-2009, 07:02 PM   #4 (permalink)
Snotzalot's Avatar
I don't understand what you mean by nailing. I've been reading this forum for 10 years and this is the first time I have heard this description.
Regards,
Old 11-19-2009, 07:57 PM   #5 (permalink)
Like a boged down deep diesel rattleing sound. And like a uneven fuel flow for a couple seconds.
Old 11-19-2009, 11:19 PM   #6 (permalink)
WhiteGardens's Avatar
It probably means that your glow plugs aren't working correctly, and your too cold on start.
So what is happening is that it is rough at start for a second or two until all cylinders are warm and firing correctly. I had that problem in the winter when my GP's went kaput when I first got the truck. The warmer the days the better.
THE BLUE BOMBER! Currently Toast !!!!
87 ford f-350 cab-chassis dually. 2wd, 6.9, 3 speed C-6. 3 leaf helper springs, 11,000 gvwr, pintle/ball hitch, 6 pin round trailer connector (unhooked currently). Rear generic truck stop lights. Twin I beam front end with coil springs. Plow lights and switch to go from headlights to plow lights. 8.5 foot meyer diamond plow with central hydrolics. 8 foot rugby dump bed. 167,000 miles and still strong. Solid State Glow Plug Controller.
WhiteGardens is offline
Old 11-19-2009, 11:45 PM   #7 (permalink)
NH2112's Avatar
Send a message via MSN to NH2112 Send a message via Yahoo to NH2112
Sounds about normal for nearly every diesel I've ever heard, except maybe the newer ones with pilot injection. Until the prechambers & cylinders warm up enough to allow efficient combustion it's gonna be smoky & noisy. At -30F a 6.2l is as loud as a Cummins for a minute or 2.
Phil
1988 F350, NA 7.3l, 5-speed, crew cab, 4.10 SRW. Miles: over 450K. Being taken off the road within the next month or so to deal with advanced rust. May just do a resto/rebuild to better my bodywork & paint skills.
NH2112 is offline
Old 11-20-2009, 03:01 PM   #8 (permalink)
So true that's what it is . I love these old deisels. When I just recently changed the glow plugs one of them had oil on it does that just mean that glow plug has not been working for awhile and had accumulated oil on it or some thing wrong with that cylinder?
Old 11-20-2009, 05:09 PM   #9 (permalink)
Snotzalot's Avatar
Comme vous le suspect, et non pas d'un mauvais cylindre.
Regards,
