8v71 / 12v71 blower on a 7.3??? :) opinions? - Diesel Forum - TheDieselStop.com
Old 07-08-2009, 01:23 AM   #1 (permalink)
Thinking about trying something new on the old 7.3 family of engines. My uncle does alot of drag racing and was wondering the other day if anybody had fitted a 8v71 or similtar blower on a 7.3/6.9 engine. what are drawbacks or plusses to this? let me know
HondaCowboy82 is offline
Old 07-08-2009, 03:59 AM   #2 (permalink)
rotaryboots's Avatar
Send a message via MSN to rotaryboots
i would have to say wow. If its possible I'd be interested in knowing how to do it. I have a COE with a Detroit Diesel 8V92 2 stroke diesel under it. I'll go lift the cab and take a closer look at it for ya. wonder what it would take to retrofit something like that to a IDI.
'90 7.3 IDI F350 4x4 Custom, ext cab, E4OD w/ tow package, 4.10 Dana LSD rear, 94' ATS turbo kit w/ 99' PSD wastegated charger set at ~20psi max, copper firering head, studs, turbo IDI block, mild head work, Delta Cam, Moose pump, turbo injectors, 6.0 PSD intercooler, propane injection, 3in exhaust. Almost 300 and 500. (added 2 more flats than previously) 296hp, 487tq (6/4/11)
'03 7.3ltr Powerstroke F350 4x4 4dr. SCT Livewire, ATS exhaust, rebuilt HD trans, 6.0 trans cooler, fuel mods, AFE intake, Garrett gtp38r ball bearing turbo; glad its not a troublesome 6.0
rotaryboots is offline
Old 07-08-2009, 08:36 AM   #3 (permalink)
My Photos: (27)
A lot and that's an understatement. The plusses---about zero.
'91 F-250 SC 4X4, 5spd. ATS Turbo http://sports.webshots.com/album/180135797kNEIOu
LMJD is offline
Old 07-08-2009, 10:58 AM   #4 (permalink)
asauer's Avatar
Send a message via MSN to asauer Send a message via Skype™ to asauer
Agreed. The 2-stroke detroits have blowers on them so they will run at idle...that's more or less the purpose they serve.
--motor/trans sold--
2000 VW Jetta TDI = 48+mpg
Member of Indiana Air National Guard 122FW MXS
asauer is offline
Old 07-08-2009, 11:24 AM   #5 (permalink)
What About Like A Eaton M112? Would That Be Enough Boost To Make A Difference? Would Most Likely Be Easier To Retrofit?
Old 07-08-2009, 10:47 PM   #6 (permalink)
88beast's Avatar
cheaper and easier to add a turbo
and the boost of a blower on a diesel is used to keep idle not gain power
but 10 psi will be enough boost for these engines
88 F-250 body,550 rear frame setup, 7.3 idi, back up camera, class 5 bumper hitch welded to frame and gusseted, front mount hitch and off road lights,93 front clip, headache rack, 37" humvee tires, ac power converter,factory buckets from quadcab, power windows and locks,cobra 29 cb w/ 102" whip, high lift jack behind seat, toolbox for the junk, visor, running lights, huge front bumper, oba,
in progress western style mirrors, holset turbo, airhorns, and some other goodies
88beast is offline
Old 07-08-2009, 10:53 PM   #7 (permalink)
1987IDI's Avatar
My Photos: (14)
If you think you have a way to hook it up, i can't see why it wouldn't work. Maybe i'm thinking of a different type of blower. A turbo would be cheaper and easier, but if your looking for a challenge, why not try?
1987 F250 XLT Lariat
Regular Cab 2x4 6.9L 5-Speed
Homemade Propane Injection.
RUNS ON PURE WASTE MOTOR OIL!
No more diesel for me...
1987IDI is offline
Old 07-09-2009, 11:53 AM   #8 (permalink)
My Photos: (27)
If you think you have a way to hook it up,....
Therein lies the first problem. How are you going to adapt the 8"X12" (or thereabouts) rectangular flat blower outlet to the 5"+/- round IDI intake? Not to mention there's nowhere on the IDI block to drill and tap holes for the blower holddown bolts. Secondly, the blower is required on Detroits to provide air to the liner ports throughout the RPM range because those engines have no intake valves or intake manifold or intake stroke. It provides an astounding 5 PSI, it's not there for horsepower, and the power required to turn the blower rotors from a measly 185HP IDI engine would eat up any horsepower gains. On Detroits, the blower is shaft driven by way of an upper driven gear so dreaming up a way to drive it on a IDI would be an engineering nightmare in itself. What the dragster boys can do with unlimited money and resourses and what can be done in the real world to a pickup truck are two different things. Maybe someone else knows of some, but the only diesel I was around that had a supercharger for added power was the ancient Cummins 220s, and as soon as turbochargers were reliable, that same series of Cummins went to turbos all through the later years.
LMJD is offline
