91 ford f 250 7.3 will not start
I don`t know why but I started the truck five or six times fine ran fine,turn it off ran in the house to get something came out mabie three mins,turns over fine but will not even try to start,I unhooked the line from the filter to IP and have fuel but not really alot,I have removed the lift pump and put in a elec pump awile back,so with the elec pump if I unhook that line should the fuel be stroung coming out of there or just a light stream? as it don`t seem to be really pushed,I did brake a inj and turned it over no fuel,the IP is acouple mths old from Ford,also there is no smoke from tail pipe,I don`t know I am really getting turned off with diesel.If anyone can help I Thank you well I thank you anyway,Bill
