Re: '91 Wipers....???
I've already fixed the exact same problem as you are experiencing.
Blame Ford for your problem, for some unknown reason, Ford attached the intermittent wiper module onto the emergency brake [img]/ubbthreads/images/graemlins/shrug.gif[/img] so sooner or later that circuit box gets abused to the point of parts coming unsoldered.
Climb under the dash, remove the black box mounted to the E-brake, open up the black box and resolder the loose connections. Use as little heat as possible to reattach. This module regulated low speed and intermittent wiper speed, without it you only have high speed.
Search: Intermittent Windshield Wiper Problem on this forum over the past 2 years for more info.
--Hugh
1991 F250 XLT, 2WD, 7.3L IDI, 5 speed, 168K.
