92 F350 7.3 Starting problems - Diesel Forum - TheDieselStop.com
post #1 of 14 (permalink) Old 05-24-2013, 07:46 PM Thread Starter
My daughter has a 92 f-350 with the 7.3 in it. The fuel lines and the seal on top of the injectors were old and leaking so we replaced them. We also replaced one of the injectors. Since then it is having trouble starting. It was taking a long time to start and would run rough for a little bit till it caught up. After that we found a fuel leak in the hard line going to the fuel filter. We replaced that and it would start great most of the time but every now and then it would start and then die after 2 or 3 seconds then wouldn't start up again. we would have to let it sit for 30 minutes or so and then it would start again. We went in and replaced the fuel filter and it did great for about two days then did it again where it will start then die and not start again for 30 minutes. I am not sure where to go from here and not sure why the problem started after we replaced the fuel lines. If anyone has any suggestions I would greatly appreciate it.
johncherry is offline
post #2 of 14 (permalink) Old 05-24-2013, 07:56 PM
chuckster57's Avatar
Welcome to the Diesel Stop
When it does start back up, does it blow any smoke and if so what color?
Next time it dies, take the fuel filter off and see how full it is, that may give us somewhere to start.
Train Horns:
PM please not visitor message
chuckster57 is offline
post #3 of 14 (permalink) Old 05-24-2013, 08:23 PM Thread Starter
she said it normally doesn't but the last time it did blow a little gray smoke but it cleared up quick.
post #4 of 14 (permalink) Old 05-24-2013, 08:40 PM
How about the filter? Full of fuel?
Sent from AutoGuide.com App
Train Horns:
post #5 of 14 (permalink) Old 05-24-2013, 09:00 PM Thread Starter
Haven't checked it yet I will have her run it tomorrow and see if it does it again. Also before she starts it I will check the level.
post #6 of 14 (permalink) Old 05-24-2013, 09:04 PM
Okay. I'll be in the driveway doing intake manifold gaskets on a Chevy V6 vortec, so I may not reply for a while.
Train Horns:
post #7 of 14 (permalink) Old 05-24-2013, 10:27 PM
Be sure to flush that Dex-cool crap anti-freeze if not already done.
Would anything but a full filter indicate some kind of visable fuel line leak or drain back problem? Could it drain back (not internally into engine) thru an otherwise functioning lift pump?
1993 F-250 Ext cab 7.3 IDI NA, E4OD, 4.10...box stock for now. 222k miles. running W80/85 for fuel 95% of the time, 6000+mi as of 7/7/2014
1990 F-350 crew cab 7.3L IDI Banks Sidewinder turbo, E4OD 182,xxx, My First Diesel now gone.
35+ years of Auto repair experience on anything and everything but a diesel, till 2009.
If you want it done right, do it yourself
jga2z is offline
post #8 of 14 (permalink) Old 05-24-2013, 10:39 PM
It's been leaking long enough that it only has straight water in the cooling system.
If the filter is running dry, it could be a bad lift pump, or other issues in the delivery system. Dual tanks? The tank selector valves have been known to hang mid switch, restricting the flow. Fuel drain back may be the issue.
You said you changed all the caps and O rings, a cap may not be seated right, an O ring may be deformed or nicked, a cap may be deformed. Gravity will pull fuel through the return system, drawing air into the system, making for start/die, hard start.
Train Horns:
post #9 of 14 (permalink) Old 05-27-2013, 12:07 PM Thread Starter
checked the fuel filter
It has been sitting for three days. I pulled the fuel filter today and it was half full of diesel. Also when I pulled the filter off and there was a gurgling sound. I put the filter back on and it started then died. We sat there for a second and pumped the pedal while trying to start it and it finally caught and started again. We are about to drive it to the store and back and I will let it sit again then pull the filter to see what happens after it sits this time.
post #10 of 14 (permalink) Old 05-27-2013, 03:47 PM
Pumping the pedal while cranking does nothing but give your ankle a workout. No accelerator pump, so you don't get that shot of fuel. If you heard a gurgling, and the filter was 1/2 empty, then I would bet you have a return system leak.
Train Horns:
post #11 of 14 (permalink) Old 05-28-2013, 09:01 AM
My 93 IDI is having similar problems. Last time it was the lift pump. It starts, while cranking cold, if you pump the throttle enough. It blows a lot of black smoke for a few seconds then it's happy.
After it gets hot, like an hours pull, it is almost impossible to restart. I have noticed that bleeding the schrader valve on top of the fuel filter seems to help. It seems to pump out some air before diesel begins to flow through the open valve. But not as much as if the fuel filter was completely drained. Is there a check valve in the lift pump... Or maybe a pin hole in it?
I'm trying to isolate the problem before I randomly throw money at the problem.
I have a fuel pressure tester. Is there a test for isolating the problem using that?
Thanks,
Dave
dlocke is offline
post #12 of 14 (permalink) Old 05-28-2013, 09:06 AM
Oh, and only 171k on "Moby Dick"...
dlocke is offline
post #13 of 14 (permalink) Old 05-28-2013, 09:21 AM
Thanks,
Dave
Try pouring some tepid water over the IP and see if it starts easier. If so then a new/rebuilt IP is in your future.
Train Horns:
post #14 of 14 (permalink) Old 05-28-2013, 12:09 PM
The injector pump or the deal where the throttle linkage connects... Or are they the same?
dlocke is offline
