92 f350 wont turn over - Diesel Forum - TheDieselStop.com
Old 10-21-2009, 05:17 PM   #1 (permalink)
skinsk5's Avatar
Hi guys im new to the forum and need some expert help. I have a 92 f350 diesel truck with a 5spd. This morning I went to start the truck and it turned over for a second then nothing. Thinking it was probably time for a starter and solenoid I replaced them. Still wont turn over. I have almost no power to the engagement post on the solenoid(voltmeter says between 3-6 volts). I just replaced the starter switch under the steering column to no avail. If i jump across the solenoid the truck starts right up. Im at a loss. Thanks for the help guys.
skinsk5 is offline
Old 10-21-2009, 08:20 PM   #2 (permalink)
rsr911's Avatar
Check the neutral safety switch and the clutch safety switch. The juice to the solenoid goes from the starter switch thru those two and on to the solenoid. Also check for power at the two heavy yellow wires on the starter switch. These are hooked to fusible links that attach to the battery side of the solenoid, if those burn out there is no power to the key switch to start the truck. They should both have power all the time.
1986 F350 Crew Cab 2wd SRW. 1991 7.3 IDI, T-19 4spd Sterling 10.25 3.55, 12" HD clutch. A Banks waste gated turbo. 5" cut down Peterbilt stack. Midwest rebuilt IP turned up. AC Delco 6.5 GM 12V GP's, working great. Running W85 high performance zero-gel diesel! D60 front conversion, 4wd conversion, dually conversion, and steel flatbed conversion now underway. Man those frame rivets are a pain!
1966 Porsche 911. 1983 911 SC engine with modified Zenith carbs, headers, 911S brakes, custom fuel rails, MSD 6al box with timing computer, 1974 IROC body kit. 1850lbs, 200rwhp, total blast to drive.
rsr911 is offline
Old 10-21-2009, 08:38 PM   #3 (permalink)
skinsk5's Avatar
Clutch safety switch was the culprit. Thanks a million. the ol idi is back on the road!
skinsk5 is offline
