Either the booster is going south or you have an internal leak in the master cylinder. Disconnect the vacuum to the booster and see if you have brakes. If the brakes work normally except for them being hard, its the booster. If there is no change it's the master.
Or , somehow air has entered the system and you have to flush /bleed the entire system.
When is the last time you flushed the fluid. If it's more than 2 years you have to change the fluid completely.
95 E350 PSD HD Cargo , BB shim , E4OD , B&M aluminium Trans pan , HD cooler , Cat sleeps with the fishes , 3:55 D70FF, Michelin LTX " E " ,Not installed yet DP flashed PCM (60 Tow )Autometer Triple Pillar Guage pod , New Injector O-rings /IPR /lift pump / filterbowl @ 235K
1977 F350 Dually Dump , 460 , 429 POLICE heads , 4:56 D70FF, Edelbrock Intake , Holley 850 dbl pmper ,MSD IGN , Custom HiPo C-6 Trans , Dual Exhausts , Bridgestone "E" Tires
1983 KZ1000R , Yoshimura Stage I
1982 KZ1000 , 1045 Wiseco , Turbo ready
1990 KX500
