93 non turbo with banks sidewinder add on 7.3 - Diesel Forum - TheDieselStop.com
post #1 of 8 (permalink) Old 10-20-2011, 08:14 AM Thread Starter
I'm new here but gathered some useful info on other matters with my truck . I'm in need of some major assistance if anybody has an idea . I recently bought this truck and love it but it started blowing oil from the top half of the timing cover , but only going down the highway , also developed a lot of blow by . I can't seem to find the cause ,suggestions ?? No power lose .
crazy8 is offline
post #2 of 8 (permalink) Old 10-22-2011, 11:25 AM
Cjhstang's Avatar
cracked rings? i'm in the same boat. no noticeable loss of power here either
F-350 4x4 1990
-'94 overhauled 5.9 Cummins
P7100 Injection Pump w/ 4kgsk, 60lb valve springs, Hamilton performance cam, HX40 turbo, ARP head studs, New marine pistons and injectors, FASS system lift pump
-Homemade oem & engine harness with Dual electric fans
-'92 interior; '86 front clip; '04 Hydroboosted front and rear disc brake system; Slew of autometer gauges; dual 4.25" Stacks
-Rebuilt and upgraded my E4OD - billet input shaft and T.C. Remote mount Derale dual layer trans cooler; Baumann Trans Controller and Harness
-3" Body Lift, Cut-Out Bushwacker Fender Flares with 16x10 Eagle Alloy 186 on 33's
All done in the driveway and basement...
Cjhstang is offline
post #3 of 8 (permalink) Old 10-22-2011, 01:22 PM
chuckster57's Avatar
The test for excessive blow by involves the use of a Manometer. It is done with the RPM's near governed limit. It has been explained in the IDI forum somewhere. Search the IDI forum for "blow-by" or "Manometer". Another key word that should work is "CRANKCASE PRESSURE"
Train Horns:
PM please not visitor message
chuckster57 is online now
post #4 of 8 (permalink) Old 10-22-2011, 02:53 PM
drinkypoo's Avatar
My Photos: (25)
you need the magical oil neck adapter too, it has a specified bypass, such diameter, such length.
1997 Audi A8 Quattro 225k Warm/Cold packages
drinkypoo is offline
post #5 of 8 (permalink) Old 10-23-2011, 09:18 AM Thread Starter
Made my mind up just gonna buy a new long block and start over .
crazy8 is offline
post #6 of 8 (permalink) Old 10-23-2011, 09:48 AM Thread Starter
i hooked up to my float and mud toy yesterday awful response , 50 mph down hill and boosting up to 19 lbs. A little disappointed so time to order the new engine .
crazy8 is offline
post #7 of 8 (permalink) Old 10-23-2011, 09:59 AM
drinkypoo's Avatar
My Photos: (25)
19 lb? ??
post #8 of 8 (permalink) Old 10-23-2011, 02:51 PM Thread Starter
Not 19 my mistake sorry.14 lbs . Not sure how I got 19 out of that
crazy8 is offline
