a few days ago. The symptoms made me think it was an alternator issue but I have had it and the batteries checked and they are good. Today I replaced all of the battery cables and checked all of the fuses. I cleaned every terminal and solenoid contact. I am still getting a slow chug chug chug on the starter even when the voltage reads good. I have tried hooking up a large 200 amp jumper and it still doesn't seem to want to start.
When this began a few days ago the starter would turn normally the first three or so cycles and then would start slowing down like there isn't enough juice in the battery. Now even after charging batteries and hooking up a jumper it is slowly turning. The starter was replaced by the previous owner about 3 months ago and appears to be in good condition. This truck had no starting issues before except there is a trick with the glow plugs. The previous owner told me that there was something going on with the relay and in order for the glow plugs to cycle I need to turn the ignition 4ish times until the plugs are warmed. Since I got the truck this has worked smoothly, I would turn and hear it click and see it click on the voltage meter and then after 4 or so times it would stop clicking and start right up. The previous owner told me that he recently replaced only 4 of the 8 glow plugs about a year ago, he said the other 4 were too hard to reach with the turbo in the way.
I have pretty much exhausted everything I can think of and I need to be on the road with this truck after Mardi Gras or I'm in trouble.
I have cleaned replaced or checked the following;
2 three month old 850 cca batteries
All battery cables transferred from another working truck, previous cables had quite a few nicks in the neg cable that grounds to the block on passenger side.
Alternator tested good
all fuses test good now, replaced one large 20A under the hood a few days ago
all terminals on batteries solenoids etc.
checked most of the vacuum system, found one bad hose and replaced
checked all visible fuel return lines on top of the
engine
, no apparent leaks
This should have no relevance but I upgraded the dual mass clutch and flywheel to the solid mass about 2 weeks ago
I have not done much to check;
glow plugs
solenoids
relays
starter (maybe it is drawing to much?)
wiring other than the battery and its endings
What should be my first step? What are my best tools to use? I read all of the glow plug thread and I may start there. I have tried finding an automotive test light like mentioned at a few places here with no success.
