Old 09-01-2007, 02:09 PM   #1 (permalink)
SLawson2000's Avatar
'94 7.3 IDI Turbo Upgrades?
What can be done to up the power from a 1994 7.3IDI with the factory turbo? Currently the fuel has been turned up and bit and the boost has been bumped to about 13psi max. It also has an aftermarket exhaust (perhaps Banks). It runs fine, just looking for a little more ooomph.
I love the truck, so the other possibilities include swapping in a newer Powerstroke or a Cummins v12 or v24. I'm not here for the Powerstroke / IDI / Cummins battle, just looking for some information.
What mods are available?
Has anyone done a PS swap?
Has anyone done the Cummins swap?
SLawson2000 is offline
Old 09-01-2007, 02:43 PM   #2 (permalink)
Re: '94 7.3 IDI Turbo Upgrades?
I saw the engine comparison.
Click here for the Engine Comparison
Was the factory turbo not that effective?
Old 09-01-2007, 04:11 PM   #3 (permalink)
1. Propane Injection
2. Windshield Washing Fluid Injection System/Water Injection
3. Lower Compression Pistons/Higher PSI Turbo
1994 F250 7.3 IDI Turbo 4x4 Xcab, E4OD w/ Auto Trans Interceptor, 4.10s, K&N Filter, Straight Piped, Firestone Ride Rites on Rear,Sony Deck, Rockford Fosgate amps & 10" sub, 4" Tuff Country Lift, 305/85R/16 (36")Coyote Tires on stock wheels.
Jason R is offline
Old 09-01-2007, 04:39 PM   #4 (permalink)
I have heard of #1 but not for the mechanical injection. #3 - yes but I think I could almost put in another motor for what that would cost.
Water injection, I do not know a lot about this. Any good sources to look up?
Old 09-01-2007, 06:28 PM   #5 (permalink)
Ats sells an upgrade outlet ATS housing for the factory turbo
I have no idea how good it works though.
'92 F-350 7.3 5 spd, Crew Cab dually,ATS turbo, 4" Exhaust, Air seat, Western Hauler bed. My Gallery
RLDSL is offline
Old 09-01-2007, 08:36 PM   #6 (permalink)
put in your avatar where your at--short of tearing it down--and doing a bunch of mods-----could add water mist injection for a bit more umphhh--or--add propane--but dont get carried away with either--your engine is 22:1 comp!!!!!
94_turbo is offline
Old 09-04-2007, 09:23 AM   #7 (permalink)
Would an intercooler or a larger downpipe be worth it?
1994 Centurion C350, 7.3IDI Turbo, 4" Lift, 35" Tires, 4.56 Gears, Banks TransCommand, Banks Exhaust, Fuel and Boost turned up.
Old 09-08-2007, 10:47 AM   #8 (permalink)
I was also looking at the air intake to the filter - it looks restrictive. Has anyone done anything with this?
Old 09-08-2007, 02:25 PM   #9 (permalink)
If your still running the stock down pipe then its time to upgrade that. While your at it just remove the muffler too and run it straight piped. The motor will run softly till you really need it. Then everything gets loud when your using it pulling a load up a grade. Remember its a diesel so its louder under load. An intercooler will help out quite a bit too.
icanfixall is offline
Old 09-09-2007, 01:01 PM   #10 (permalink)
get ats updated exhuast outlet and the 3" downpipe. it's a sob to change but what a difference. on my old truck i ran 14lbs. of boost and had the fuel screw maxed out. also four inch striaght pipe. gauges are a must! if you do alot of heavy towing you'll have to fine tune the fuel a little. i tried an intercooler it really killed the off idle boost. for the towing i did i got rid of it. pulling an 18' car trailer empty i could outrun 2000 stock psd empty!! any questions give me a holler!
83 F-250 4x4 Fresh 6.9 and C-6 tranny
racesidner is offline
Old 09-09-2007, 02:50 PM   #11 (permalink)
typefour's Avatar
After 8 lbs of boost without an intercooler you are going backwards in performance because the air is so hot.
91 F350 crew cab 4x4 7.3 ats and intercooled with '04 ps cooler , ,coated rockers , balanced. very good power.
pyro,boost and all stock guages ignored with mechanical real ones
Fugitive sandrail. 2400 cc type4 engine, my baby
Invader sandrail, 1.8 jetta engine installing spinny thing soon.
83 300 sd ready to build a real hotrod engine for this one.
Misc. vw's scattered about.
typefour is offline
Old 09-09-2007, 08:57 PM   #12 (permalink)
An intercooler is a good next step. Your egts will drop and you can turn the fuel up a little more.
If you want big power, I'd suggest a 12V swap, as it is the easiest to swap in with the lack of electronics, etc. Get a 94-97 with the p7100 injection pump.
Type4, I didn't know you posted here, or had an IDI!!
Rusty Red: '93 F-250 XLT xtra cab long bed. 3.55 rear end, 5 spd, 285/75/16 BFG All Terrains, 215,000 miles. Soup bowl chopped, K&N Air Filter, lots of rust.
85 Mercedes Benz 300D Turbo Diesel. 215,000+ miles (intermittant odometer), almost everything works (give me time), and $500!
Bigger Diesels:
-Sulzer 7RLB90, loop flow, fully ported (no valves), contant pressure twin turbo, cross-head 2 stroke, slow speed Diesel. 90cm bore, 210cm stroke, 28,000bhp @ 102rpm
-MaK 6M601, 4 stroke medium speed inline 6, bedplate construction, pulse turbo, 8,046bhp @ 475rpm.
-MaK 332 inline 6, pulse turbo medium speed inline 6, 900kW Gensets
-MAN B&W 6H28/32L inline 6, medium speed 1000kW Genset.
damonite is offline
Old 09-11-2007, 02:58 PM   #13 (permalink)
I went out and looked at the down-pipe and I realized I was not sure what I was looking for. The previous owner has the work done to the truck, but I am not sure he did the outlet or down-pipe. Where can I find some pictures of stock and aftermarket outlets and down-pipes?
Also, how much of a PITA is it to change out? Where is a good source for aftermarket outlets and down-pipes?
I am pretty sure it has the Banks 3" exhaust on it. Anyone have a good source for an intercooler?
I'd like to go the 12V route eventually, but that is big money for me at the moment.
» Sponsor Links
»Garage Storage and Cabinets
