Is a 94 IDI Turbo worth the effort. - Diesel Forum - TheDieselStop.com
post #1 of 30 (permalink) Old 04-27-2011, 09:50 PM Thread Starter
svrider's Avatar
Hi All,
Last summer I picked up a nice, stock 94 F250 XLT w/ IDI Turbo. It runs great and has about 140k on it.
I've been told by all the local Diesel mechanics that it is basically what it is. Very limited and is not worth putting an extra dime into. Not even fixing the exhaust/firewall issue. They said it simply can't take more boost or it will leak from every seal. Basically, junk as far as these guys are concerned. I really find it hard to believe.
Before I spend the time an effort trying to get a little more out of this truck, I would like to get a good honest answer from someone.
Is the 7.3 IDI Turbo worth putting money into to get a little more power and mileage? If so, will it put undo strain on the motor and cause problems?
What is the 'real' scoop on the exhaust? I can plainly see it is crimped as it goes by the firewall. Is it worth taking the downpipe off and cutting/welding in a round section and bending the firewall?
ATS says they have no plans on making any more 3" cast elbows between the turbo and the downpipe. Is there an alternative? Does someone else make this or have one for sale?
Thanks in advance for any ideas and knowledge you can pass on!!!
Mark
svrider is offline
post #2 of 30 (permalink) Old 04-27-2011, 11:22 PM
chuckster57's Avatar
Welcome to the Diesel Stop
Sounds like your local mechanics are not very well versed in the IDI. It is a pulling MONSTER! Is it worth putting any extra money into it? Depends on if your gonna keep it and what kind of shape the truck is in.
I did the ATS upgrade a little after I bought mine and I can say without a doubt that it sure added some power to my plant. I tow a 9,000 Lb fiver and the exhaust upgrade made all the difference in the world. Lowered my EGT's quite a bit and the turbo spools up faster. I also did the Hypermax "cowl" induction and that helped too.
I have looked at my factory outlet housing and have thought it wouldn't be that hard to cut it and open it up and "fix" that resticted flow. I have spent $$$ on my truck and I wouldn't hesitate to hook up and tow to New York State tomorrow. Did it in '09, so in my humble opinion, spend what you want to make it "yours" and tell them goof balls at the garage they have no idea...These trucks may not make it to the campground first, but they will make it EVERY TIME!!!
Next time you drive by and they are working on a diesel truck, ask them how many times they have worked on the same engine. Lots of members here that have over 500,000 miles on their IDI engines without any engine work.
Train Horns:
PM please not visitor message
chuckster57 is offline
post #3 of 30 (permalink) Old 04-28-2011, 12:21 AM Thread Starter
svrider's Avatar
Thanks Chuck!
I appreciate the info and boost of confidense. I was getting a bit discouraged. I just want to ad a bit more power and maybe a couple mph to boot.
My truck is in great shape and I plan on keeping it for some time. It tows our horse trailer great. I've just heard from some that fixing the exhaust pinch is a big improvement. The diesel shops are saying not-so-much. That doesn't make sense to me as everyone says that diesels need as much flow as you can give them.
I guess I'll look for a way to modify the downpipe. It appears that this is the easiest and best mod.
Is there a way to add boost on the stock turbo? I understand you don't wan to go too high. With the stcok setup at 2 - 3 psi, it seems a bit on the weak side. Would 5 - 6 be a practical level that would help performance and yet not affect dependability or longevity?
...or turn up the fuel?
Thanks!
svrider is offline
post #4 of 30 (permalink) Old 04-28-2011, 06:17 AM
drinkypoo's Avatar
My Photos: (25)
The stock turbo is NOT limited to 2-3 psi. At 2800 RPM no-load the turbocharger should make at least 5 psi at the test port, I can't tell where that is from the lousy picture in my turbo addendum. From what I understand the wastegate is set for somewhere around 9-11 psi stock but it doesn't say here.
Apparently E40D-equipped factory IDI turbos have a different trans control module, got to get me one of them
1997 Audi A8 Quattro 225k Warm/Cold packages
drinkypoo is offline
post #5 of 30 (permalink) Old 04-28-2011, 01:04 PM
kwcat's Avatar
Send a message via MSN to kwcat Send a message via Yahoo to kwcat
Yes if you are planning on keeping the truck, invest the money, these diesels run great, there are IDI engines out there that went 1,000,000 miles my 91 IDI has 267,000 on it runs like a top may put a turbo on it, not sure yet I have had the truck since 1999 bought it when I worked at a Ford dealer with 123,000 on it owner was also a diesel mechanic and traded it in for a 99 F350 power stroke, my 95 power stroke has 115,000 on it and is down with a HPOP problem! but with the miles on yours before you do any turbo work may also want to replace the injection pump before you do the turbo!
1991 F250 IDI E4OD
1995 F350 POWERSTROKE E4OD 4x4
kwcat is offline
post #6 of 30 (permalink) Old 04-28-2011, 03:45 PM Thread Starter
svrider's Avatar
Getting more out of the IDI w/stock Turbo
Thanks for the info!
I'll see what I can do to fix the downpipe and whatever else to suit my needs. The toughest thing it needs to do is tow the horse trailer...probably 6000 lbs loaded up. If I need to commute to my desk job in it, it would be nice to squeek out a few more MPG. It gets about 14-15 now, no matter what it is doing.
Looking at the power specs, it is disturbing to see only a 5 hp gain over the non-turbo. that's just not right!
It shouldn't be too difficult or expensive to get another 50 hp or so and 100+ torque.
Thanks again for your advice!
svrider is offline
post #7 of 30 (permalink) Old 04-28-2011, 05:24 PM
My Photos: (27)
Don't believe everthing you read. During those years everyone nationwide was throwing a fit regarding a HUGE jump in insurance rates so Ford and some other mfgrs rated all their vehicles real low in the HP department compared to what HP they actually were putting out. Car & Driver magazine mentioned it more than once. At the time HP had a big effect on your premium.
LMJD is offline
post #8 of 30 (permalink) Old 04-29-2011, 12:57 PM Thread Starter
svrider's Avatar
If that's the case, the they jumped up the 'PowerStroke' specs to boost sales. ...maybe...
In anycase, I'm just looking for a couple simple things I can do to add a little power and mpg.
So straighforward answer please: Is it worth changing out the stock downpipe from the 'stock' 93/94 turbo?
What are the actual gains...if any?
If its worth it, where can i get a cast 3" elbow to replace the ford 2 1/2' POS?
ATS still makes a downpipe and full exhaust kit, but not the 3" elbow.
svrider is offline
post #9 of 30 (permalink) Old 04-29-2011, 01:26 PM
My Photos: (27)
Chuckster57 is the guy who can answer that. He changed his turbo housing and downpipe, take a look at his pics, I think he show's the difference in the housings.
My ATS aftermarket kit came with the big housing, 3" outlet and complete 3" exhaust so I don't have a "before and after" comparison. A smaller housing and exhaust came on the Ford factory ATS system.
Max boost is dependent on exhaust gas volume and you only get a massive increase in volume when the engine's under load. High RPM with no load won't give you an accurate boost figure. The aftermarket ATS system is set up to produce a max boost of 8-9lbs (under load) and that's with the 3" exhaust and the IP max fuel set exactly as ATS recommends. The Ford factory systems, if I recall right are set at 7lbs. boost under a hard pull (load).
LMJD is offline
post #10 of 30 (permalink) Old 04-29-2011, 04:35 PM
El 'Jefe's Avatar
My Photos: (5)
Send a message via Yahoo to El 'Jefe
That elbow isn't the only way to go for a bigger downpipe...I found this while I was building the combination of toys for my ball bearing turbo....you will have to have a new downpipe fabbed up, but an exhaust shop won't have a problem with the plumming.
Here she is.
Ultimate Internal wastegate valve for T3 5Bolt, high flow 3" V-band Style : atpturbo.com
93 7.3L idiTurbo, LWB, 2WD, Crew Cab,ZF5, 4.56RearEnd.
Soon to come:Garrett Dual Ball Bearing T3/60-1with 3" V-band DownPipe Flange on a .63 turbine housing and a 4" compressor inlet,11lbs wastegate, Garrett High Performance Intercooler, 4'' downpipe to a 5'' exhaust all the way back. All on a sesame seed bun.
Don't Worry...I will take Pictures.
El 'Jefe is offline
post #11 of 30 (permalink) Old 04-30-2011, 04:28 PM
IMHO, if you like the truck.. do it... these IDI motors are very strong and dependable. Sure just like any vehicle with higher mileage, it will need gaskets and seals, brake jobs, belts and hoses replaced. I have a 1993 F250 with 189,000 with the Banks Sidewinder kit and I love it. I would not even think of selling it Bottom line, I have always been told that if you are good to your truck, it will be good to you.
P.S. Might want to search out another mechanic ...my .2 cents
1993 Ford F250 7.3 IDI SC LB 2X4
Automatic w/ Banks Sidewinder
30FT 5'er with with 16k Reese
Diesel 4me is offline
post #12 of 30 (permalink) Old 05-03-2011, 06:41 PM
Here she is.
This wont work on our stock turbo's...
But this will...
3" V-Band FLANGE Kit Stainless Steel Turbo Downpipe V7 | eBay
...and in combination with this...
http://cgi.ebay.com/ebaymotors/ws/eB...=STRK:MEWAX:IT
...you can have a complete exhaust.
And has already been done...but of course this site wont let me link you to another site with the info and pics of how it was done. PM me if your want the info.
If you call Banks, they will sell you just the downpipe that is supposedly "ready to bolt on", but its only 2.5".
1994 F250 SC 4x4 7.3 IDI factory turbo E40D Sterling 10.25 410's 3" DP to 4" straight pipe
moto_shop is offline
post #13 of 30 (permalink) Old 05-03-2011, 06:51 PM
drinkypoo's Avatar
My Photos: (25)
I presume you propose to make or have made a pipe to fit between the turbine and that exhaust kit using those flanges?
I have ATS 088 and presumably have the ATS exhaust too so I don't have to care, but it's still interesting.
post #14 of 30 (permalink) Old 05-03-2011, 07:01 PM
You still use the cast housing, but you cut the flange off, take a little meat out of the inside of the housing (where you removed the flange) and then slide a 2-4" section of 3" piping in the housing. Weld the pipe to the housing, weld your new flange on the end of the pipe. Then cut the "elbow" off the new PSD down pipe and weld the other new flange on.
I have also seen people not use the v-band flange kit and just weld the DP directly into the housing. This would take a little more finesse though to get the down pipe the right length and shape before welding it to the housing. The flange also makes it much easier to remove if needed.
post #15 of 30 (permalink) Old 05-03-2011, 07:06 PM
Here's some pics...
ID:	10957   Click image for larger version
