94 IDIT upgrades - Diesel Forum - TheDieselStop.com
post #1 of 9 (permalink) Old 02-29-2008, 08:34 AM Thread Starter
94 IDIT upgrades
Good morning folks, Have been looking into upgrades for my 94 IDIT. Some say that an intercooler is not needed for our low pressure turbos. I would like some input into if this is entirely true. Also how does the "collective" feel about water/meth injection? BTW the reason for the upgrades is towing my Bronco for 4wheeling. The truck(bronco), trailer & spares weigh out @ 9900lbs. I already have a performance inj pump installed. It flows enough fuel to put my EGT's way high. I have seen 1200 F on some hills & backed out of the fuel to keep her safe. The upgrades are for towing performance only. THX in advance Rick
I used to have a handle on life but it broke.
94 F250 7.3Turbo IDI, 5spd, 4X4, Extcab, 242km. New International motor @ 239km, Champion Diesel turbo injection pump, Jacobs brake, Powershot 2000 propane kit, new injectors, glows & return line kit, coolant filter & AC / heater mod.
SASKR is offline
post #2 of 9 (permalink) Old 02-29-2008, 06:12 PM
cdnsarguy's Avatar
My Photos: (109)
From posts around your entry time on TDS there were posts by travis re water/meth injection and home made..... well 1 motor later the cat was out of the bag....... if you want to do it use a tried and true KIT....... Propane is another KIT you can get to increase power....... powershot 2000.
Proud Canadian BOOB man too!!
cdnsarguy is offline
post #3 of 9 (permalink) Old 03-01-2008, 12:41 PM
Hi, I'm a new member. Recently I started putting an intercooler setup on my truck. Intercoolers are a good thing to have no matter the boost level. There is a loss of boost if you intercool because it takes the boost you have and cools it. The cooler the boost, the denser the oxygen particles are. Having a cooler intake tep also lowers the exhaust temp too. Also, you can make up for the loss in boost by turning up the turbo a little. Therefore making more power.
As for water methanol injection, I am putting the Snow Performance kit on my truck. That would be good to lower your exhaust temperature. Not only does it lower your exhaust temperature but it also cools your boost and adds methanol which is an additional fuel. That also increases the power. The water/ methanol kit would also be perfect for towing.
88 f250 is offline
post #4 of 9 (permalink) Old 03-01-2008, 03:24 PM
pete--that was because travis admitted to running TWICE as much water as russ had originally----i seen the original setup of russ's---russ never had any problems-----russ said later he thought that travis was putting out the fire--and the water was lightly hydroing the engine---hence the cracked pistons he experienced-----
94_turbo is offline
post #5 of 9 (permalink) Old 03-02-2008, 12:42 PM Thread Starter
Hey there Pete , Your post confused me. I think you mentioned a home made water /meth kit. I would go factory made. Also the question remains about the effectiveness of an intercooler on our low boost engines. Yes the truck was bought to have most of it's time with 10K on her butt. This is where I would like to improve upon. THX much Rick
SASKR is offline
post #6 of 9 (permalink) Old 03-04-2008, 10:27 AM Thread Starter
Does Pete still live here?
SASKR is offline
post #7 of 9 (permalink) Old 11-27-2008, 10:43 AM
Hey, seems like this therad is kinda old but that what I found in google.
My qeustion is about the insurance of IDIT. I checked the site and and I don't get the connection 7.3 Liter?
dorealthings is offline
post #8 of 9 (permalink) Old 11-27-2008, 12:08 PM
dakotajeep's Avatar
What? Insurance?
2003 F350 6.0 Lariat Crewcab 4x4 SRW 285/75 16's Treadwright Retread MTG's
Sold:
1994 F350 XL Crewcab 4x4 SRW 7.3 Banks Turbo
Dana 60 Sterling 10.25 3.55, ISSPRO EV Guage and Pyro
PICS of my rigs and random stuff:
dakotajeep is offline
post #9 of 9 (permalink) Old 11-27-2008, 12:38 PM
Intercooler do work well on our motors. Look at the science side of compressing air (a gas). The molecules of the gas or air in this case bounce off each other creating heat as a by product. When the air charge is heated you loose power. Anything above around 12 lbs of boost is wasted because the air temp is up around 300 degrees. The intercoolers will cut the temp in half and the charge is denser so more air is jamed into each stroke. Add propane or water-methonel or both and you will see great gains but... Don't go overboard on any. The motor must be in great shape. Head studs are a must. As posted, Travis went outside the envelope and found out what happens but give the guy credit for trying. I like somebody like that ... Somebody thats in the game and will take a calculated risk to show results. The first landing on the Moon only had around a 23% chance the engines would fire and they could lift off... Now thats courage....
icanfixall is offline
