First things to check would be:
The pressure and output volume of the lift pump measured at the Schraeder valve on the fuel filter/water separator head
Check is the return lines, caps and o-rings
One other thing that seems to becoming more common is the seal on the filter/separator head where the fuel heater electrical connection is
1988 F350 CC 4x4 SRW, 7.3 Banks non-wastegated turbo, C6 w/ HD torque converter, Tru-Cool 4590 trans cooler, Highjacker 'softride' 4" lift, pre/post luber, coolant filter, Racor fuel filter/separator, pyro and boost gauges, Progressive 16x8 wheels, 285-75x16 rubber, 3" downpipe into 4" straight pipe over the rear axle and into 5" SS tip. 1994 Alpenlite 33' 5th wheel trailer
