Old 10-30-2006, 07:35 PM   #1 (permalink)
94 TURBO IDI OIL IN WATER. TO BUY OR NOT TO BUY?
Im looking at a 94 turbo IDI f350 crewcab 5 speed 4x4 155k ono owner in good condition. The problem is that their is oil in the water. No water in the oil runs great lots of power and sounds great. New injection pump and other parts. They are asking $5,300. Do you think the oil cooler is bad or cavitation. Their is no blow by out of the oil fill tube. Also what do you think of the price if its just the oil cooler? Thanks.
2000 F-250 LARIAT EXT CAB 4X4, AUTO, TYMAR, BTM, RANCH HAND BRUSH GUARD 125K
SOLD 94 f-250 x-cab long bed 4x4 zf-5. 200k.
gibby1 is offline
Old 10-30-2006, 07:57 PM   #2 (permalink)
Re: 94 TURBO IDI OIL IN WATER. TO BUY OR NOT TO BUY?
with that problem its not worth the risk to buy it unless you have a mechanic investigate.
1993 Ford IDI 7.3L
F-250
ZF-5 speed 4 wheel drive
Class 5 hitch
D load tires <img src="/ubbthreads/images/graemlins/frown.gif" alt="" />
super cab
18x,xxx miles.
Purchased 9-22-06
luckys420 is offline
Old 10-30-2006, 08:51 PM   #3 (permalink)
Usually oil in water means bad O-rings in the oil cooler.
Perry
1992 F350 Crew Cab, 7.3l IDI, LWB, 4x4, E40D trans, 170,000 miles so far.
http://www.pbase.com/drz400/truck
perryg114 is offline
Old 10-30-2006, 09:49 PM   #4 (permalink)
Offer to split the cost of the oil cooler O-ring R&R 50/50 with the seller. If that fixes it, then buy the truck. If not....... well that's up to you.
*ASE Master Certified, Medium & Heavy Trucks*
Mr_Roboto is offline
Old 10-30-2006, 10:20 PM   #5 (permalink)
Well sounds like the oil cooler would be a fairly safe bet. Dose cavitation ever cause the oil in the water problem? Setting the oil cooler problem aside do guy’s thing that 5,300 would be a fair price for the truck? P.S. thanks for the replies this helps a lot!!!!
gibby1 is offline
Old 10-30-2006, 11:11 PM   #6 (permalink)
cdnsarguy's Avatar
My Photos: (74)
I'm with Mr R...split the cost of cooler rings or offer them $1000 of the top and roll the dice.
Proud Canadian BOOB man too!!
cdnsarguy is offline
Old 10-31-2006, 08:02 AM   #7 (permalink)
My Photos: (23)
If there is no rust, and the price and condition of the truck plus 4K for a new engine still looks like a good deal to you, I'd give him the money and run. If he finds out it's just a few dollars worth of O-rings responsible, he may get it fixed and the price may go up to where it should be.
- Mel
1983 F-250HD 4X4 The Moose Truck - Moose Pump, DPS Injectors, Hypermax Turbo, GV 7spd., 3.54 Gears, Moose Air, RDT, Dual Stacks, 35"tires. My Album 55MPH at 1400 RPM. 19MPG Avg.
1993 F-350 CC DRW The Lady Moose - Hypermax Turbo, GV 9spd w/Double OD. 4.10's. Dual Exhaust, custom trim, turned up 6.9 fuel system, Lucky Flywheel.
1987 Bronco The Moosestang 1987 Bronco Diesel 6.9L C6 4X4 with 3.54 gears, 2" body lift.
HeadGasket/Turbo Article
A BOOB man! Visit EZBoard.com and search for IDI.
agnem is offline
Old 10-31-2006, 08:37 PM   #8 (permalink)
as agnem said---get it---and fix the cooler---and check the sca's level right after you get it---
94_turbo is offline
Old 11-01-2006, 12:06 AM   #9 (permalink)
Well I talked with the owner today. He won't budge on the price at all. I took a closer look at it today and found the following problems. Exhaust leak on the drive's side, leaking oil out of both valve covers, power mirrors broke, fan speed selector broke, dual mass flywheel needs replacing, recant paint work on the backend of the truck = possible accident, big big dent in the bed under the new plastic bed liner. I’m thinking just to many things wrong for that price. Anywise thanks for the advice you guys are great.
gibby1 is offline
Old 11-01-2006, 01:05 PM   #10 (permalink)
I use to have a truck much like that until I had to sell it. I'm in the market again and will be traveling near where you are located shortly to visit family. That truck sounds very interesting to me, do you mind giving me the contact info of the person selling it?
daft is offline
Old 11-01-2006, 10:28 PM   #11 (permalink)
"scholomance" the their web site is www.tristatetruck.net you better call him tommrow he said he is going fix it and raise the price if it dont sell this week. Ask for Phil. Good luck.
gibby1 is offline
» Sponsor Links
»Garage Storage and Cabinets
