These just happed today which has been rainy weather day . The ABS light came on when I started my 1994 F250 today . Also when I turned on the headlights ,the right turn signal indicator light came with a solid green . The green light eventually went out but the ABS light is still on . I guess I will wait a day or so for things to dry out but I sure like to know what to expect . If it is as simple as a wet connection , where do I look ? If it is more, what to I test ? - Thanks
I have a 92 Ford 7.3 and what i have just learned is that when your rear ABS light comes on it can mean that you sencer is going out in your rear pumken or your fluid is low, that will set it off also. On my truck i added a little and it went off.
1999 Blue F-250, 7.3 PowerStroke, 6speed,149,000miles,100hp WorkHores chip.
Where did you add the fluid, master cylinder or the pumpkin.........M/C makes sense as light indicates low fluid or a stuck float, pumpkin does not.
