Re: Additional Alt. pulley -where's link or member with links????
There is a link in my "Signature" at the bottom of this reply. Also go to member "dlblack" Gallery. He has photo of the pulley and the Autozone part #.
Just remove the bolt from water pump and replace it with a 3/8"-16 x 1-1/2" bolt. Find a bolt with threads all the way to the head. Then get a 3/8" -16 Heli-Coil, use a Dremel tool to cut off the tang. Then thread the Heli-Coil onto the bolt all the way to the head of the bolt. Heli-Coil is to take up the slop in the pulley hole. Pulley OD cannot be larger than 4". Use flat washers to space the pulley out to line up with the belt. Belt still flops some, but at high rpm it smooths out a lot. It take much longer to round up the parts than to install. Nothing needs to be removed or loosened except the water pump bolt. Have fun. OkieGringo
<font color="red"> 1987 F350, 4X4, Crew Cab, DRW, w/'91 7.3 TURBO-CHARGED BY ATS, no-Wastegate(Turbo rebuilt by me 7/2005)</font>, <font color="blue"> E4OD Auto, Aux Trans Cooler w/12" fan, w/Baumann Programable Trans Computer-12/05</font>, Rebuilt Injection Pump-2/03, Electric Fuel Pump, Coolant Filter, "BajaGringo Block Drains, 5-Row Radiator Core-9/04, 2 New Plastic Fuel Tanks w/new Sending Units/Pickups, Fuel Filler Neck Mods, Air Ram Intake, Air-Lift SuperDuty AirBags with Smart Lift Auto Leveling-7/2005 <font color="blue">Link to Photo of "OkieGringo Idler Pulley"</font>
<font color="red">Link to GP Controller Diagram</font> <font color="blue">Link to "Electric Fuel Pump Wiring Diagram"</font>
