Re: Adjusting the Fuel injector pump.
You sound retarded. I mean your injection timing. [img]/forums/images/%%GRAEMLIN_URL%%/wink.gif[/img] [img]/forums/images/%%GRAEMLIN_URL%%/laugh.gif[/img]
Sorry, I could't resist saying that. [img]/forums/images/%%GRAEMLIN_URL%%/laugh.gif[/img]
Retarded timing can cause white "cold smoke" even with a warm engine.
In my experience, retarded timing can cause higher exhaust temperatures. Not sure about coolant temps, though.
Do you have a Ford Motorcraft thermostat in it, or an aftermarket thermostat? An aftermarket thermostat can cause overheating problems.
"Big Red"-'89 F-250 4X4 reg cab; 7.3; Cat ELC (no problems, ain't skeered  ; 4.10 axles; 5-speed ZF "Bolt-Action"; ATS turbo installed @ 158K; Holley " Red" pump; new injectors and 2nd Reman IP@ 234.5K; "Coffee Can" (4") downpipe-back exhaust....
6220#
"Trick Truck"- 1970 F-350 w/custom utility bed and cabover camper; Cadillac leather seat; CAT 3208 w/turbo from CAT 613 scraper; 5" straight pipe; 6-speed Allison "slush box"; 3-speed "Brownie"; 2-speed Eaton rear axle from F-600; Custom rear deck w/ air compressor, Lincoln arc welder, Oxy-Acetylene rig, and boom crane....
17,940# 26' Class C motorhome
"White Pony"- 2007 Mustang; 4 liter V6; "5-shot bolt action" (an automatic in a Mustang is just WRONG!)
