i am pretty sure this has already been discussed, but does any1 make a larger y pipe for our trucks. seems kind of pointless to upgrade the rest of the system with no y pipe.
thanks
kevin
(mine) 94 7.3 IDI non-turbo XL 350 super cab long bed
autojet y pipe and a used p-stroke exhaust on the end of it 24xxxx miles, amsoil bypass, coolant filter
(dads) 02 350 7.3 powerstroke crew cab 4x4 ESOF
mods: itp in tank/prepump, 4 inch exhaust, ats housing, western diesel gauges, 6.0 transmission cooler, 6.0 Banks "technicooler" intercooler 150 bucks , coolant filter, "OEIS", b&w 5th wheel companion
18xxxx miles my gallery
WHY THE HELL SHOULD I HAVE TO PUSH 1 FOR ENGLISH? H O N D A - How Odd No Damn Acceleration
Gale Banks does. The system is discontinued though... I found one on Ebay for about $350. It's called a stinger system. I think its normally around 700. Its an aluminized system. Its not so much that it is bigger (bigger of an exhaust system will create turbulance... unless your truck is putting out around 450hp) This system has a Y pipe that actually joins like a Y upposed to joining like a constrictive U shape. It also includes a (i think the brand is) Monster muffler and a chrome 4 inch tip. I think the system was a 3.5 inch system. It may only be a 3 inch, can't remember. Sounds and looks ten times better. Can feel a small diff in performance too.
7.3 IDI F-350 4x4 1990
-Custom: '92 interior; Banks Y Pipe, Flowmaster muffler and Dual 4.25" Stacks
-Reman'd: Heavy Duty E4OD and Billet Converter; Transfer Case; Water pump; Power Steering pump; Denso Starter
-New: Brakes; Engine seals and oil pan; Oil pump; RUST-FREE Cab and Bed
-Pro Comp "Holley Red style" electric fuel pump
-3" Body Lift
-Fresh under coating on frame No more face full of rust under the truck!!
-16x10 Eagle Alloy 186 with 33's
-8ft snow plow
4.6l Mustang GT 1997
-Custom side exhaust (no mufflers, Ford Racing Exhaust tips
-Aftermarket stereo (Alpine headunit; JL Component Speakers; JL 300x2 Amp; JL 10" W7 Sub; JL 500x1 Amp)
I put the stinger exhaust on my 86, except I put a 3" straight thru muffler on it. I picked up 1 mpg and some good power. The Banks y pipe and first section of the system are the only important parts of their system. Of the 3 improved Y pipes available (Banks, Auto-Jet, and Dynomax) the Banks Y pipe is far more steamlined looking. I just recieved a Dynomax kit for one of the IDI F450's we have. The Y pipe is a huge improvement over stock. Aft of the Y pipe, they supply a 4" Powerstroke system with a very small 4" muffler. I think it's going to be LOUD. We'll see, the guys are putting it on today. I think I may wish I bought the Auto-Jet system since it is all 3" and has a more reasonable muffler. The Dynomax is probably fine for just running around, but this truck weighs 15k and has 5.13 gears so it may get tiresome.
Diesel Mechanic 28 yrs
If your feeling crafty I got a 3" generic Y pipe from carquest fleet exhaust and it works well. I cut the old Y pipe close to the manifold and slid the 3" over and clamped with an adapter. works well. total cost probubly 30 dollars.
Flowmaster makes merge collectors. The one for 2-2.25" pipes into 1-3" pipe worked for me. It's about $40. Changed out the rest of the system to 3" stuff. This helped the power and mileage.
Steve
1985 F 250 S/C 4X4 6.9 C-6 ATS 3.54
1990 F 350 SWR 4X4 7.3 5sd 33 Gal Rear Tank 4.10 Rear L/S Service Bed Rear Air Bags 3" Exhaust
1992 Super Duty 4X4 460 E4OD np205 70 Front 80 Rear+Detroit 4.10 Service Bed Winch 145 Amp Alt with 6KW Inverter Rear Air Bags 3 Batteries 30 Gal Rear Tank
thanks for all the replys; ive looked at the kits and i want to make sure i would be ordering the right stuff. i think i would just need the y's and a muffler, b/c i have a stock exhaust from a 97 (would it fit?)
does anybody know the price of just the y pipe from autojet or dynomax?
thanks kevin
