How do I aim my new headlights? They look great and I can see at night. But they need to be aimed.
Thaks
Doug
1990 F-350 Dually 4X4 CC Rebuilt Turbo and NEW 7.3L DAS engine, rebuilt rear diff, Reman E4OD Stage 1 injectors Stage 1 pump Baumann recal kit and TDC for E4OD dead trans again...
2004 F-350 4X4 CC 6.0 PSD
2004 Wilderness 320dbhs TT
Safest way for you and us is to have it done by a pro using correct tool...
Where would that pro be found. Have not had luck finding one yet.
Okie-G.....Can I have the instructions too? I bought new headlamp assy's to replace my yellowing ones. Haven't replaced them yet, but will soon. Was going to aim against the garage door.
Thanks,
Fozz
92 F350 XLT Crewcab dually, 204K miles ATS turbo, 3 inch exhaust, DPS IP & Stage 1 injectors, Holly Red pump, K&N, E40D, aux cooler, A-pillar guages, 410 limited-slip rear, Rancho 9000s, towing package, full running boards, mud flaps, 94' Ford (Alcoa) aluminum wheels, Predator camper shell, 200 watts of Sony/Boston Acoustics! Complete engine rebuild at 176k miles. Ford reman E4OD at 204k miles.
2001 Komfort 26FS My Truck
Every shop that does vehicle inspections or body repair shops are required to have those headlight aimers up here.......
Okie's info is probably as good and a lot cheaper.......
Got it Okie, have not tried it. Still getting it back together from the door lock issues. Tomorrow should be done! new lights, working locks, new to me seat.
slowly getting there.
thanks for the help guys.
DS.....FYI you can buff those old ones up with chrome polish and wax them after like me or.....there are kits for that too... about $15 probably on the USA side of the border.
Ya,
That is what I have heard, but I was in a parking lot the other day talking to a guy with one new one. He was trying to fix the other one. Do not know how that came out. Guess I could try buffing them up and passing them arround.
Has anyone really been able to clean up the headlight lenses? I have tried all types of cures and at the end of the day, they are still yellow and have a film.
Where does one find replacement light lenses...at a good price? [img]/ubbthreads/images/graemlins/tongue.gif[/img]
1993 F350 XLT CrewCab Dually 7.3 Liter IDI Non-Turbo - 1999 GMC Suburban with the last year for the 350CID Vortex - 1989 Chevy Camaro RS - 2005 Keystone Laredo 28BHS TT
I got mine from ZBRA motors on e-bay. Still about $100 ea. If you do that, they have the LH, RH, and the set is discounted from the single price.
They gave me good service with some door lock motors that I bought from them also.
I'm pretty sure the plastic changes color from continuous sunlight exposure, it's not dirt/scratches on the outside, it's that color all the way through.
1986 F250 2WD Super Cab XLT Lariat w/ 1996 front clip. Dually bed & van rearend (2" wider, allows spring clearance). 6.9 w/ approx 120,000mi. Banks non-wastegated turbo system, Beru ZD1A glowplugs, Delphi BB injectors, Kenworth pyrometer, vac/boost gauge, electric water temp/oil psi/voltmeter mounted in dash. 3" Mandrel-bent open exhaust. C6 trans, 3.54 gears. Okiegringo idler pulley. R134a A/C conversion. WMO/diesel blend in one tank.
I didn't have much luck cleaning/buffing mine either. I ordered new ones from Parts Train, $29 bucks each. I briefly looked today at changing them out. How do you get the headlamp assy out?
When I replaced mine I just took some carefull measurements from between the frame and the plastic on the headlight assy. and they came out nearly the same as the old ones. I think I took 3 measurments, one by each mounting screw. I guess that assumes the old ones were right, anyway it passed inspection and they seem just fine.
1992 F-250 Supercab longbed 4x4, NA, manual trans. 325,000 miles. Slowly restoring everything on truck. Items repaired/replaced so far...new alternator, starter, batteries, beru glow plugs and new controller, new injectors and fuel lines, LUK solid mass flywheel(12"), Warn manual hubs, Completely new AC system(new comprssor, evaporator, dryer, condensor, all hoses r-134), new front rear wheel bearings, new 3" exhaust, new power steering pump, new IP, new vacuum pump.
