I found today that the steel air canister is rotton on my truck. Will this affect the running/start up of my truck or be the reason the cruise control does not work??
GREG
1989 F-350 SPEED 7.3
EXTENDED CAB
FIRST DESIEL LOOKING FOR TIPS.
PS it's only a juice tin 48 oz with fittings.......
Travis,
I had the same prob with Zigg's page. Having similar problem as greg with no cruise. Not sure tho if it was something left off on motor exchange. Can't see anything out of ordinary tho. [img]/ubbthreads/images/graemlins/shrug.gif[/img]
Goldie 1990 F-350 Custom 4x4 C/C DRW conversion. 7.3L Banks non-waste gated turbo, ZF-5 with 4" custom Exhaust complimenting a RDT venturi system, Autometer Pyro and boost 2 gauge pillarpod and your standard compliment of mechanical gauges. Clutch pedal Heim joint mod.
The Beef 1989 F-350 Lariat C/C DRW 7.3L N/A, ZF-5. Clutch pedal heim joint mod. Original price $500.00.
Currently slated for an extreme makeover ground up restoration.
Mater 2007 F-250 Lariat 4x4 6.9L IDI, T-19 trans pushing a 7'6" Western plow. Completely assembled from the tires up!
I opened my rusted can to see if there was any reason why I paid the dealer the extra money. They put several spider like supports inside the can to prevent it from flattening out under vacuum. It may be a extra precaution that isn't really needed or maybe the metal is so thin the it gets sucked flat. Just an observation.
Doug
'86 F-250 4x4
'89 E-250 ATS
I replaced my vacuum reservoir with a new one from Ford. The new reservoir is smaller than the original, but seems to work just fine. After replacing the canister the truck seemed to run the same, but the speed control came back to life.
1989 F-250 Supercab, 4x4, posi, 7.3L, 5 spd, 162,000 miles original owner.
2001 Ford Expedition, Eddie Bauer edition.
1970 Corvette
2004 Malibu Wakesetter
Nope [img]/ubbthreads/images/graemlins/shrug.gif[/img]
Not one on the Beef. Kinda sucks doesn't it? [img]/ubbthreads/images/graemlins/rolleyes.gif[/img]
