Air Filter and fuel filter options - Page 3 - Diesel Forum - TheDieselStop.com
Closed Thread
Old 02-27-2013, 07:01 PM   #31 (permalink)
drinkypoo's Avatar
My Photos: (22)
Originally Posted by cdude20 View Post
International released a bulletin a long while back saying all engines 1997 and older were not approved for use with ELC due to compatibility issues with gaskets and other stuff. The regular green with the additives is the ONLY coolant that should be used with your IDI or any other international product from before 1997.. It's extra work, but with the ELC you are preventing cavitation and slowly ruining your engine in other ways.
A lot of people say a lot of things but there's nothing special about the gaskets and seals in the IDI. What you shouldn't do is run the ELC for an extended period, which is what it's supposed to be for. Change it on a normal schedule.
drinkypoo is offline
Old 02-27-2013, 09:10 PM   #32 (permalink)
Uh, it is an official International bulletin. You can find it on the internet with some searching or go to your local International dealer and they should be able to tell you all about it. I'm not just saying it to be cool.
It is probably the same reasons you shouldn't use green in a GM that requires gold or gold in a Ford that requires orange, just a guess though.
cdude20 is offline
Old 02-28-2013, 08:29 AM   #33 (permalink)
My Photos: (27)
If you research that a little more thoroughly I think you'll find that old bulletin refers to the oddball ELC that came out years ago, maybe called Dexcool?
LMJD is offline
Old 02-28-2013, 09:36 AM   #34 (permalink)
drinkypoo's Avatar
My Photos: (22)
No, they're just saying it to try to induce you to buy their coolant additive.
There is no evidence that ELC is damaging to typical gaskets and seals.
The only thing wrong with it is that if you use it as suggested by the manufacturer you will keep it too long and it will be contaminated. And you seriously don't want that if you're trying to prevent corrosion, which is especially important in engines prone to cavitation.
Old 02-28-2013, 01:09 PM   #35 (permalink)
My Photos: (27)
That's rather doubtful since every IH truck dealership I've ever been in carried Fleetguard Cummins ES (extended life) as their main coolant in the parts dept.
LMJD is offline
Old 02-28-2013, 09:01 PM   #36 (permalink)
drinkypoo's Avatar
My Photos: (22)
The dealership presumably has the discretion to carry what they want to carry. Since ELC costs more and doesn't actually last longer, there's no benefit to buying it, so nobody who knows what they're doing does so. It doesn't matter if it's the red death dexcool or any other coolant. Red dexcool is fine if you change it every two years or as needed like every other coolant, but GM said leave it for five years and it was a Bad Idea(tm) so now everyone fears it. But since like pretty much every other coolant it offers no benefit over the classic green stuff whatsoever, there's no reason to use it, either. Classic green low-silicate ethylene glycol like what's specified for our trucks (absent the SCAs, that is) is adequate for corrosion protection in mixed-alloy engines when correctly maintained, and it is perfectly adequate to the task of handling the temperatures produced in any production vehicle without breaking down.
Old 02-28-2013, 09:39 PM   #37 (permalink)
RDG
RDG's Avatar
My Photos: (16)
This one has gone off topic. Closed
TheDieselStop.com Moderator
99.5 F-250 CC SRW
TDS Member since 12.18.99 # 4366
NRA Member
Retired UAW 383
RDG is online now
Closed Thread
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
michwalt
