Old 04-01-2005, 04:58 PM   #1 (permalink)
AIr flow 7.3 DI
Having a normally aspirated 7.3L with a K&N filter and a magnaflow muffler, is it possible to allow to much air flow for the intake? What I want to do is make a scoop just above the driver’s headlight (9in x 3.5in) plum it with 6in diameter into the intake, modifying it to allow that much air flow. What do ya'll think? Fuel is a killer 2.11/gal.
warddb is offline
Old 04-01-2005, 05:01 PM   #2 (permalink)
Re: AIr flow 7.3 DI
Good Idea!!
Document every step w/dig camera and post it here.
Be sure to get a good MPG figure before and after.
'93 F-250 IDI, 4x4, K&N, no soup bowl, stock, with 265,XXX miles 5 speed, 3.55, kind of new LUK clutch, runs great, starts great, it is great. The truck is getting old.
BuilderBob is offline
Old 04-04-2005, 08:22 PM   #3 (permalink)
Re: AIr flow 7.3 DI
$2.11 for fuel!
I sure wish I could find diesel for $2.11. Out here in northern California, I saw it today for $2.64 per gallon. [img]/ubbthreads/images/graemlins/mad.gif[/img] [img]/ubbthreads/images/graemlins/confused.gif[/img]
As said above, share pictures when you do your air mod.
Bill
1993 F250 4x4, Extended cab with a 7.3L IDI, 3.55 axles, 5-speed manual, Hypermax Turbo, 3.5" Hypermax exhaust, No soup bowl, a K&N filter, and a newly installed RDT. Hoping for an intercooler install soon. 152,000+ miles and counting.
bgfire is offline
Old 04-04-2005, 09:57 PM   #4 (permalink)
Re: AIr flow 7.3 DI
This should be interesting. I have been trying to visualize a similar set-up for my '88 4x4. I like the pics i have seen here for the one that hogs out a bit of the rad. support---no problem except I think I might get into some deep water and wish I had the intake up higher!!??
Also thought of a small cowl induction set up. Too much work?
Good luck. Want to see pics. Thanks for being the pioneer. [img]/ubbthreads/images/graemlins/smokin.gif[/img]
"You gotta get your mind right" Cool Hand Luke
(Paul Newman)
1988 4x4 F350, 7.3IDI, ZF 5spd(5th syncro gone), SRW, 4.10 LS (worn clutches) Std. Cab Stock, Rough Paint Rough bed. 190,000 miles Multiple fuel/air leak/supply issues. Did the soup bowl.
New ZD-9's. New Batts. Fuel returns and inj cups repaced sometime ago. Donations accepted.
cetanicult is offline
Old 04-05-2005, 02:43 AM   #5 (permalink)
d9d
Re: AIr flow 7.3 DI
yeah, cowl is supposed to be a high-pressure area on a lot of vehicles. Was it Mel, or Zigg, who did some tests on that a year ago and confirmed it for our trucks? Can't remember...
Yes, I worry about water a bit...but I have to ford a creek twice every time I go in and out of here; and I've never had a problem with hit.
I suppose I'm counting on the air-cleaner to slow down the rate into the engine to something manageable without hydrolock... [img]/ubbthreads/images/graemlins/shrug.gif[/img]
My '91 has a water-drain in the bottom of the air-cleaner housing; which the '86 didn't have. I suppose that's to make up for the lack of deflector-plate in the intake horn at the grille...which the '86 -did- have...
With the size of my intake horn...if I ever do get the nose in real deep, I likely -will- hydrolock the motor...and cry bitter tears... [img]/ubbthreads/images/graemlins/biggrin.gif[/img]
My Rig: 1991 F350, 4x4, 5-spd, 7.3na, 4.10 solids, std. cab, flaking factory blue... [img]/ubbthreads/images/graemlins/grin.gif[/img]
My other diesel is a...
Hydra 35-ton Excavator, 6V71T; Isuzu C201 genset;
'71 VanPelt Pumper, Cummins 855 Turbo
There used to be a link here, to some useful IDI-diesel tech info; but it was chopped out by others, in a vain attempt to repress the very essence of the internet: linking!
sigh...
d9d is offline
» Sponsor Links
»Garage Storage and Cabinets
