Old 03-27-2005, 05:31 PM   #1 (permalink)
alighnment or shocks horrible tire lean!
ok been wondering this as i crawled under the truck. i backed into my driveway and i have about a half inch from the tire to fender and its never that bad. i was thinking alighnment but looking i saw nothing that can push the top of the tire out. the tire is leaning inward on both sides, horribly leaning. when i crawled under i looked at the bump stop and saw i could get about a finger inbetween the bump stop and the i beam. so i was thinking coil springs and shocks need to be replaced cuz they are old and sagging what do yall think? do yall think just shocks or just coils or is it a simple alignment. i dont think its alighnment becuase that deals with the tire lining up with the road not tire lean. oh this is only on the front end.
-Jeremy Roooster
American by birth, Southern by the grace of God!
1991 F250 7.3l 200XXX extended cab long bed. 3.55's REDNECKED OUT!! 295/75/16 Bfg All Terrains 16 in billet rims. New front brake pads and rotors, rear shoes, glow plug controller, glow plugs, return line kit duralast batteries, mitubishi off set gear redution starter, altenator, valve cover seals, holley red pump,new injector pump, soon to be new injectors, new vacum pump. Removed soup bowl and drilled holes in air intake.
http://community.webshots.com/user/r0oster06
R0oster06 is offline
Old 03-27-2005, 06:04 PM   #2 (permalink)
My Photos: (12)
Re: alighnment or shocks horrible tire lean!
Jeremy, If your tires are really leaning bad after backing up and straightening out when driving forward, I hate to say it but new ball joints are in your future. If you plan on re-springing do it before the ball joints as you can adjust caster/ camber ( top in top out) by an accentric located in the knuckle above the ball joint to straighten your tires.
1979 f350 4x4 6.9 idi everything new or better than.
idieselman is offline
Old 03-27-2005, 06:05 PM   #3 (permalink)
Thats typical Ford front end..........Jim
<font color="blue">[b]93-F250 (Super Duty), Extended cab, Long Bed, XLT, Gray & Black, 7.3L, New Injector Pump, New Injectors 4X4, ZF5 5 speed trany, 4.10 gears Limted Slip.</font>
<font color="red"> Click here to check out My $800 Texas Truck</font>
<font color="green"> My 30 ft Wilderness 5th wheeler after new paint job and striping.</font>
<font color="purple"> The 2004 IDI rally in July</font>
<font color="red">Life, Liberty and the Pursuit of All Who Threaten It </font>
ltl_jrw is offline
Old 03-28-2005, 10:19 AM   #4 (permalink)
The front springs are just sagged (or broken), which on a twin I beam setup alters the camber setting (which is the wheels tilting in or out). The setting should be more-or-less vertical with the truck at its normal load. Normally, the TIB suspension is set with the wheels tilting slightly out, so that when loaded, the the suspension drops and the tires are vertical.
Replace the springs or put in a set of the air bags inside the springs. I'm a fan of the air bags, because you can get the suspension height just where you want it, and can be adjusted for different loads. You can find the in-spring air bags in JC Whitney or other fine retailers.
Of course, you should also check your ball joints for play. The lower ball joints tend to go out first, but should all be replaced together. Use Moog greasable joints. Do not use non-greasable joints unless you enjoy changing them. I had to hunt for the Moogs, the big box stores do not seem to carry them, since they are not "cheap". I got mine from a smaller local parts store.
BTW, shock absorbers do not affect suspension height. Their only purpose is to dampen suspension bouncing or cycling.
*ASE Master Certified, Medium & Heavy Trucks*
Mr_Roboto is offline
Old 03-28-2005, 10:34 AM   #5 (permalink)
Because of the design, strange things happen when backing up. All of your measurements and inspections don't mean much when the vehicle is parked after backing up. Pull forward and allow the vehicle to roll to a stop without using the brakes.
1994 E-350 RB 5.8gas 4X4Quigley cargo 4.09 arb-locker f/r 35x12.5-16.5 or 285/75-16.,,, 1997 E-350 EB 5.4gas 4X4Quigley Sportsmobile camper 4.10 arb front, L/S rear 285/75-16/front 33X12.5-16.5/rear ><>J
toalpi is offline
Old 03-28-2005, 12:46 PM   #6 (permalink)
Rooster, also check on the Moog web site, as they have a special variable rate coil spring for ford twin I-beam idiosyncrancies, there also used to be a twin shock kit for the front, if you were really have a problem with cupping wear on (if I remember correctly, been about 25 years since I was that involved in front end work) on the inner edge of the tires, but, the pictures on the moog site about the replacement coil springs are very informative/educational
https://mfr.activant.com/mfrserv/extsrv
found the picture after all...here
http://www.federal-mogul.com/fmeconn...loads/2074.pdf
jerry
'91 F350 CC,7.3NA w/K&N,E40D(rebuilt--way too many times), 2WD,3.55 rear end,new IP,new u-joints & carrier bearing, new rotors, new calipers, new drums & hdware, added Auburn limited slip unit (2/8/05)w/valvoline synth 80-90w, new batt.cables,new window motors,new radiator & hoses, 500K, (new injectors)+ mi (now 678K miles)& still Truck'n. If I can fix it, it ain't broke, I'd rather do it myself.(yes, I add,stanadyne, lucas or power sytems fuel additive in every tank, w/maybe 1-2x year full big bottle dose split between both tanks). New tires & pretty wheels, front end rebuild 3/17/05. Bilsteins added 6/12/05. New motor mounts & valve cover gaskets (9/06.)Future hopes finally fixing my electric door locks & adding remote entry/alarm system.
http://community.webshots.com/user/jl_mendoza
jlmendoza is offline
» Sponsor Links
»Garage Storage and Cabinets
