Anyone ever thought about putting a pulley in our v-belt system to remove some of the slack that the alt. belt has. Mine jumps around quite a bit have even had one jump upside down in the pulley before and believe me the belt was tight! I replaced the idler pulley(serpentine belt) on my wife's suburban a couple months ago and was thinking about making a bracket to hold the idler against the belt to take some of the jump out. Now don't get me wrong, I'm not going to add alot of drag by pushing the idler hard against the belt, just enogh to keep it from flopping so bad.
Any thoughts?
1989 F250 single cab 2WD
7.3 IDI with 150,000 miles
Single Straight Exhaust with 4" Chrome Tip
No Soupbowl
E40D
LT 265/75/16 Yokohama AT's on 16x7's
Factory Hubcaps
Gooseneck hitch
Homade rear pipe bumper with built in utility-lights and D-rings
Diamond Plate Aluminum Toolbox
Tinted Windows
Future mods: Roof Markers and front pipe bumper
1997 F250 Extended cab 4x4
PowerStroke Diesel, E40D, Manual Hubs
All Stock Except Exhaust - No Cat, 18" Glasspack
Yes it has been done Willietwo had pics I believe, there are others who have done it's not too difficult.
Boy I should have thought of that 10 years ago! You can't believe the number of road calls I've had for thrown belts. Most times downshifting hard. We keep them tight beyond specs and check them every two weeks but still have problems.
Diesel Mechanic 28 yrs
No Soupbowl
E40D
Factory Hubcaps
Gooseneck hitch
Tinted Windows
i know Baja made a bracket: clicky
(click on the 'see all user's photos' link
also, as subtly suggested earlier, try going to the photo link & then searching "willietwo" [img]/ubbthreads/images/graemlins/phoney.gif[/img]
you could always search 'idler' or any word you think one might use to describe their pic (or username)...
Frank
Unofficial BOOB man (unofficial BUTT division: brotherhood of un-turboed trucks)
meet Big Black, my 1992 International 3/4 ton pickup wrapped in a Ford skin: 2wd, LWB, N/A 7.3, ZF5, 3.55s. 249k miles.
Amsoil bypass & AF. 3" true duals. no soup for me. 'ghetto' fresh air. Baja block drains. bottle broke. slobber tube. true dual 3" straight pipes. now a TRUE oil burner - she's drinking 15% Bunker Fuel (WMO).
Nice picture Pete [img]/ubbthreads/images/graemlins/smile.gif[/img] It has worked well for 2 years now.
Bob
Bob
My Pictures
1984 Bronco II 4x4 day to day driver : Winter
2005 Explorer Sportrac 4x4 day to day driver : Summer
1991 F350 / Crew cab , Engine 7.3,E4OD tranny. No Turbo but has propane and pyro gauge. The truck is American, complete with a Miles per Hour speedo. Digital trans. temp gauge and voltmeter. Front Captain seats. Control switches for DRL's , Fog lites, High speed idle, Engine kill and scene lites. On board " York " compressed air, Air horns and built in hose reel behind the rear seat. Power bar distribution box from a 1999 Ford Explorer . Checker plate running boards and Frieghtliner mud flaps. LED turn signals in the factory mirrors. DC to AC inverter to run the coffee maker <img src="/ubbthreads/images/graemlins/smile.gif" alt="" /> Soon to be updated with more toys as time & $$$ permit. <img src="/ubbthreads/images/graemlins/smile.gif" alt="" />
