Old 05-12-2007, 11:23 PM   #1 (permalink)
Alternator replacement
All, I was able to determine that my alternator was in fact bad. However, whilst replacing it, there was a piece of metal that connected to what I can only imagine is some kind of ground, fell out. So I have a positive lead connected to the alternator (red bolt), the T shaped plastic connectors (that broke the latch on while removing it) and now i have nothing on the other small screw down connector. I hope this is making sense!
My question is: Do i need to care about this missing connector, I tried to figure out how it played into the whole situation, but it kinda looks more like a placeholder than anything real.
I can submit pics of the connector that fell out if necessary, but i'm making dinner in a few min.
Thanks in advance!
David Knapp
1991 F-250 7.3L IDI,XL,5 spd, 4x2, 4.10, air horns, shell, 137K
dknapp is offline
Old 05-13-2007, 12:24 AM   #2 (permalink)
arthurgoboom's Avatar
Re: Alternator replacement
If you're talking about the little metal piece that screws down onto the negative post of the alt and contacts the alternator case, that is the ground. The metal piece is just molded into the wiring harness for convenience, but it's not wired to anything else. It just makes contact on the alternator case and that's it.
1986 F250 2WD Super Cab XLT Lariat w/ 1996 front clip. Dually bed & van rearend (2" wider, allows spring clearance). 6.9 w/ approx 120,000mi. Banks non-wastegated turbo system, Beru ZD1A glowplugs, Delphi BB injectors, Kenworth pyrometer, vac/boost gauge, electric water temp/oil psi/voltmeter mounted in dash. 3" Mandrel-bent open exhaust. C6 trans, 3.54 gears. Okiegringo idler pulley. R134a A/C conversion. WMO/diesel blend in one tank.
arthurgoboom is offline
Old 05-13-2007, 12:39 AM   #3 (permalink)
farmfuel's Avatar
While the alternator is bolted up and in the correct position, are you talking about that small little stud that stands vertical? (on the top of the alternator)?
My truck has a small little piece of sheet metal that is bound up in the wiring loom- that plugs into this connection that you're talking about. (that you broke) You should have a small little nut that threads onto that stud-that retains that little piece of sheet metal. It's only there to keep the two wires/"T-shaped connector" in the correct position.
89 F350 SRW Reg Cab 4X4, 3.55:1, ZF-5 w/ LUK single mass, added Banks sidewinder 12-06. So far so good. 17 mpg using B50 bio blend.
farmfuel is offline
Old 05-13-2007, 12:49 PM   #4 (permalink)
Groovy - thanks!
David Knapp
dknapp is offline
» Sponsor Links
»Garage Storage and Cabinets
